Page 678 of 808 FirstFirst ... 578628668674675676677678679680681682688728778 ... LastLast
Results 6,771 to 6,780 of 8072
    Oct 2015
    #6771
    Quote Originally Posted by Janemar View Post
    Blocked/clogged egr with not throw white smoke, mag CEL or pending cel lang yan related to MAF sensor or EGR due to outside acceptable exhaust flow values dahil may bara.
    Eto possible causes.
    1. Too much oil collecting sa piston or sa intake especially if parked on lng periods.
    2. Injector leaking fuel on top of piston if parked too long.
    3. If nagbabawas coolant, could be coolant leaking sa egr cooler and hinihigop makina. You can verify if may carbon traces sa coolant.
    You can rule out glow plug, alisin mo fuse or relay ng glow plug. If lumala usok, then should be a couple of dead plugs. If same qty. Ng usok lang, not plug related.
    Yup, I was thinking no.3. Coolant may be leaking from plugged cooler into the exhaust. Already cleaned the MAF sensor prior to EGR valve replacement. Hopefully not the injector or turbo seals.
    Mar 2004
    #6772
    No CEL doesnt mean walang code. Maybe pending code pa lang or intermittent ang problem or both thats why it was not lit yet.
    Better have it scanned by a competent tech nanichecheck ang bawat parameters of sensors if within range... Also, oil in the charge pipes/intake is completely normal. That's why some put catch can to remove this oil blowby sa intake.
    If your blowing bluish/white smoke or loosing good amounts of oil. Yun ang di normal and could be coming from worn piston(excess blowby) or turbo seal.
    had it scanned bro. no codes.
    Nov 2007
    #6773
    Mine is euro 4. Will try to have the MAF cleaned diy.
    Mar 2004
    #6774
    update:
    i went to the talyer and was told they cant replicate the problem. but when i was on my way home. it blew black smoke. way too much. govt dump trucks will be put to shame on how much smoke i was blowing. so had a u-turn. called the mechanic that i will do a drive-by so he can see the smoke. and was he shock.
    so i asked him what to do. and he looks dumbfounded.
    so i decided to bring it home. scanned (as told by janemar) with and elm bluetooth. and got an air sensor error. cleared it.
    then closed the egr. did a diy egr blanking. and filled up with shell nitro diesel.
    been driving it for 3 days now. and a first 20 liter nitro diesel and a 44liter nitro diesel.
    observations are. no visible smoke. no loss of power. no hiccups yet. no cel. did a scan for 2 days and no pending errors too.
    if it continues without problem. then i can conclude that its the egr. could be getting stuck.
    will update if any problem shows. unless nothing happens. then nothing to update. hehehe
    Nov 2007
    #6775
    Quote Originally Posted by baker123 View Post
    update:
    Low power with black smoke is dirty egr. Happened to me 1.5 yrs ago.
    What's your scanning tool?
    Mar 2004
    #6776
    Quote Originally Posted by JJB View Post
    im using a generic bluetooth elm with adroid app obd car doctor.
    bro jjb how did you fix the egr ? replace? clean? or block?
    Nov 2007
    #6777
    Cleaning lang at 2k+ at casa.
    Where do you buy a generic bt elm and what particular model?
    Mar 2004
    #6778
    bought it at oh el ex. few years back. no brand. just said elm 327. interface. supports all obdii protocols. have worked with strada crdi. mitsu evo4. dmax 08. subaru fxt. did not work with toyota fortuner v 07.
    #6779
    That is a good toy....
    Our 7-year old GS is showing minor signs of wear and tear....
    Occasionally, the driver's door would not lock/unlock. The flashers are indeed a good indication if everything's in order.
    And then a few nights ago,- the brake switch got stuck. It was a good thing that I normally check the unit after I parked it. A couple of light kicks on the pedal turned of the brake lights....
    Yup,- it's not part of the "all lights off" feature when you remove the key from the ignition....
    _/_/_/
    31.6K _/_/_/_/_/_/_/_/_/_/
    #6780
    time to get a new model bossing. kaso lang wala pang all-new.
2008 Hyundai Starex (Gen. 4)
