Results 1 to 8 of 8
    Hi,
    Sorry if this may seem as a stupid question, I'm kind of a newbie with car maintenance. The smoke from the buses outside is going inside my car, hence I get suffocated. What part do I need to repair/replace to prevent this from happening? This is for a 2005 honda civic by the way.
    Dec 2008
    Have someone check the air vents and hoses coming from the engine to the cabin. Baka sira na mga rubber plugs/gaskets.
    Dec 2010
    di ako sure pero malamang may cabin filter yan sir dun sa bandang ilalim ng glove box. agreed to mikoy sa vent lang pwd mag daan yan. or baka may mga siran gromet sa engine compartment.
    Aug 2006
    Sir baka naka-on lang yung "outside air" sa air selection switch.
    I think ito yung dash ng 2005 Civic:
    or baka sira na iyong a/c filter mo kaya pumapasok na exhaust fumes ng mga kasabayan mo sa daan. easy to remedy if that's the case. just bring it to a reputable a/c shop
    Jan 2009
    Most likely causes:
    1. Recirculation mode is turned off
    2. Recirculation flap is stuck open
    3. Recirculation flap seal is worn-out, broken or missing
    agree ako sa kanila sir... baka naka-open yung air vent mo kaya pasok lahat ng usok... switch on mo yung recirculation then obserbahan mo.. pag ganon pa din dalhin mo sa suking shop...
    May 2012
    Sir baka sira na po ito MOTOR ASSY., FRESH & RECIRCULAR .
Smoke outside is going in my car
