Results 1 to 1 of 1
- Dec 2010
- 1
December 12th, 2010 02:49 AM #1Hi Sirs/madams, Good Day. Sirs/madams, question lang po sa mga may ari ng FD Civic po dito. Napansin ko po kasi kanina habang naka full stop (with hand brakes engaged) po, when i press the accelerator and maintain my RPM into a specific value for about 2 seconds and more (in this case mga nasa 1500) then bitawan ko ang pedal. the RPM needle goes down, pero it goes up po ng kaunti imbis na tuloy tuloy po bumaba. prang ganito po. Stop. engage hand brake. at first gear, press the accelarator then maintain rpm ng 1500. let go of the pedal. RPM needle goes down into 1400, then 1300, 1200 then 1100, then 1000 pero it goes up po into mga 1100 then 1200 then babagsak na po into zero. parang pumipitik po. ask ko lang po if normal po ba yun due to the ECU? or need po ipacheck? thanks po in advance.
