Results 1 to 10 of 10
    Jun 2008
    mga gurus baka may nakaexperience n nito sa inyo, nabbwasan kasi ung power steering fluid ng 96 vti k, naoverhaul n ung pump tsaka rack ang pinion dhil dun tumatagas dati wala nmn leaks from the hoses nabbasa kasi ung belts e dun namin napansin.
    Kung nababasa belt eh di sa hose may tulo
    Sent from my iPad using Tapatalk HD
    Oct 2011
    Quote Originally Posted by darkbloodlestat View Post
    ayusin ang leaks sa hoses.
    You better fix it as soon as possible bro....
    Power steering fluid is corrosive and it will destroy components in the engine bay, like your compressor or alternator....
    16.7K:sampay:>:weathermanf2:
    Dec 2011
    Dumadaloy po ba yung streering fluid sa engine? Ganito din po sira nung city exi 97 ko nagbabawas pero every 3~5 months ako nag top-up. Yung sira naman sakin ser rock and pinion daw, 1.5k ung quote ng repair kit..
    Apr 2009
    Hindi dumadaloy sa engine ang power steering fluid.
    Aug 2012
    same scenario here, i parked my car at our garage, i saw leaks of power steering fluid until i opened the reservoir for power steering fluid its already half empty, i brought my car asap onto nearest petron for checking, they said it will cost me around 4k for materials + 1k or 2k for labor, per mechanic it can be used for 6months pa, what ive done is bought powersteering fluid and filled my reservoir, and filling, theres no leak na, do i need to fix it pa? will it affect my engine? steering? or whatsoever?
    thanks mga bro..
    Jun 2007
    Quote Originally Posted by lardcas View Post
    Quote Originally Posted by isa1023 View Post
    ang ibig sabihin yata eh sa external parts ng engine, especially lower parts
    in our old car, na damaged yung alternator kasi nag short (or fused) mga windings
    Jan 2012
    Ang tagas nangagaling sa clamping ng mga hoses lalu na kapag matagal na, kapag idle hindi natagas pero kapag high rev dun na sumisirit fluid kasi lumalakas pump pressure.
    Jun 2008
    salamat mga pards, ok n ung leaks, had my pump OH sira ang oil seals, paayos nyo or pcheck nyo yan if u encounter nababawasan fluid, corosive nga yan, from my exp nasisira tlaga mga belts. usually the leaks are coming from the hoses, sirang power steering pump or worse sa rack and pinion (which costs a lot to O/H)
power steering fluid nbbawasan
