Results 1 to 7 of 7
October 8th, 2013 11:44 AM #1
Last night nag-blink na yung "H" warning ko pero hindi naman dumating sa point na hindi na nagbblink at naka-ilaw na lang. Pagdating ko sa bahay chineck ko kung ano possible problem. Check coolant reservoir (normal), Radiator Coolant level (normal). Upon further checking, napansin ko na may mga oil stains with dirt sa paligid ng engine, sinipat ko and dun ko nakita na may leak between the lines, yung nagdudugtong sa lower and upper part ng engine. Please advise if ang problem nito is sa gasket lang and if need ko na din mag change nung gasket.
Also checked the oil level and mejo mababa na nga cia so I've decided to temporarily added some to replaced the lost oils.
Honda City I-Dsi (2004) CVT
TIA
- Jun 2004
- 1,311
October 9th, 2013 01:10 PM #2Is it from the valve cover or somewhere else? Normally pinapalitan valve cover gaskets (plus spark plug oil seals if applicable). Madali lang naman yun at mura lang, kahit DIY kaya.
October 10th, 2013 12:02 PM #3
Pag binuksan ko ba yung valve cover nun walang piyesa na mahirap ibalik pagkatapos. Baka kasi may mga springs dun tapos pagbukas ko maglundagan tapos di ko na maibalik. TIA.
- Mar 2012
- 351
October 12th, 2013 08:11 PM #4naku. ako may oil leak din, pina check ko kanina parang may tagas oil seal nang tranny. kailangan ibaba at palitan nang oil seal. di naman daw aabot sa 7k. ok na kaya yun?
- Jun 2004
- 1,311
October 14th, 2013 12:03 PM #5
- Jun 2004
- 1,311
October 14th, 2013 12:04 PM #6
- Mar 2012
- 351
Tesla Philippines
