Results 1 to 9 of 9
    Aug 2009
    Hi,
    Tanong ko lang po kung alam ninyo kung ano rason kung bakit di umiilaw yung "D4" habang nasa "D4" yung gear. pero lahat nung ibang gear naman meron. With regards naman sa hatak and shifting,wala naman problema. Is it just a loose connection or busted bulb? need ur insights po and suggestion regarding this.. btw my car is a 2000 accord. Salamat po...
    Feb 2005
    Quote Originally Posted by niner9 View Post
    Hi,
    If you feel and confirm that there is no problem in shifting (reaches 4th gear) then that is a likely case of a busted bulb.
    Dec 2007
    Yep, most likely just a burned-out LED. You can leave it as it is or have it replaced - either way it's relatively painless.
    Nov 2007
    The bulb is busted, you have to remove the panel at the speedometer to have it replaced, have it brought to a reputable shop for replacement.
    May 2007
    Saan pong D4 light ang busted? Is it in the gauge or ilaw sa kambiyo mismo? kung sa gauge, remove the gauge and palitan mo lang bulbs, if your unlucky like mine, mhrap maghanap ng rice bulb na sobrang liit, that's why pnagpalit palit ko na lang ilaw ng gears ko. d4 ma ilaw d3 and d2 wala. pero it doesnt affect performance at all. kung may ilaw naman yng sa kambyo mo all good na yan
    yung sa akin ganon din sa 1st gen crv. pinapagpag ko yung instrument panel umilaw na loose connection siguro.
    Aug 2009
    mga sir maraming salamat po sa mga insights at reply nyo..bumalik nanaman yung ilaw ng D4 ko ngyon.. actualy it already happened twice na.. yung una was mga 2 weeks ago, nawala tpos mga 3-4 days bumalik ilaw, tpos nung saturday nawala ulit tpos bumalik nanaman sya ngayon..probably its just a loose connection lang nga mga sir. I'll just have it checked.. Salamat po ulit..
    May 2007
    bumabalik naman pala eh. all good na yan... pagsabihan mo lang ulit na pag aalis magpapa alam... hehe... baka nga loose connection lang
    Aug 2009
    hehe..oo nga e.. salamt mga sir..
No "D4" light
