Results 1 to 10 of 34
- May 2013
- 78
December 9th, 2013 01:02 PM #1Need your help mga master..anu kaya problema ng city kpag hard starting? Sabi un daw battery pero ok nmn ung busina. Hindi ba kapag mahina or problematic ung batt maapektuhan din dapat o hihina ung busina or it's not always the case? Automatic po ung kotse and as expectd ok kpag isineries ung batt (kc syempre tumaas ung voltahe)..maari kaya na starter ung problema? Kung sakali magkanu kya aabutin pagpapagawa? Btw, 51K na ung mileage..tnx mga sir.
December 9th, 2013 01:19 PM #3
you have to diagnose it carefully... start with the battery.
just a thought, i had a friend with the similar model ng city mo.... same problem... ignition coil ang problem.
- May 2013
- 78
December 9th, 2013 01:30 PM #4
- May 2013
- 78
December 9th, 2013 01:33 PM #5
December 9th, 2013 01:47 PM #6
not sure kung magkano sa labas. pero alam ko inabot ng 18k yung sa kaibigan ko sa casa eh.
anyway, diagnose muna mabuti.... i am not saying na ignition coil yung sira nung sa iyo.
Ignition Coil Failure Symptoms
http://www.doityourself.com/stry/6-s...coil-failure#b
Starter Failure Symptoms
http://www.ehow.com/how_4845780_spot...d-starter.htmlLast edited by 1D4LV; December 9th, 2013 at 01:49 PM.
December 9th, 2013 01:53 PM #7
Our 09 City A/T does not have this issue yet....
But our mileage is still below 20KKm, and we have not yet changed the original battery.
21.8K:bike3:
- Jun 2004
- 1,311
December 9th, 2013 01:55 PM #8Iba pa yung ignition coil sa starter, starter problems are usually for much older cars, repair would probably cost around 1k if the problem is with the starter solenoid.
In my case with ignition coil problems usually the vehicle would not start anymore until you replace the coil, around 2k yata bili ko dati pero ibang model ng kotse.
I would start by having a battery shop check the health of the battery.
- May 2013
- 78
December 9th, 2013 02:16 PM #9Thanks mga sir.. Battery po una ko suspect pero since ok nmn ung busina at ilaw s panel, im thinking bka hindi battery ang problema..so i thought better ask for opinion muna bka meron n dito nakaencountr ng gnitong issue.. Kung starter man ang prob, any idea how much would it cost for repair or replacement.
December 9th, 2013 02:29 PM #10
ganito yan eh....
start ka muna sa battery.
tapos check mo yung spark plugs and high tension wire.
tapos check mo yung distributor.
tapos starter.
tapos tsaka pa lang yung ingition coil.
kung repair lang naman ng starter, mababa lang yan..... baka mga nasa 2k lang yan the most.
ang yes, by having your horn and dash lights working does not mean to say na ok pa ang battery. the battery needs around 13volts to start-up. the horn and the dash lights can function even if the battery is below 5volts na lang.
Tesla Philippines
