Results 1 to 9 of 9
September 23rd, 2012 10:35 PM #1
nagpalagay ako ng bagong bulb sa headlight, then nang gamitin ko sa gabi napansin ko ang ilaw eh nasa kanan lahat ang buga, kahit yung headlight bulb sa kaliwa nasa kanan din papunta ang ilaw, dito sa driver side ko medyo malabo, na try ko na din i adjust ang gear para sa pag adjust pero wala pa din nangyayayari ganun pa din, by the way im using honda civic 96.. dko na alam kung pano gagawin dun sa headlight kahit anong adjust ko sa kanan pa din ang buga.
- Jan 2011
- 445
- 53,883
September 24th, 2012 12:27 AM #4if you still have the owner's manual, i think it is outlined there in detail.. in more modern cars, holes with markings can be found on the headlight housings. you insert your adjusting tool (typically a flat blade screwdriver or a philips screwdriver) and turn.. in less modern cars, the adjusting screws are not marked, but are still easy to access..
why not try googling it? maybe it's there. try "honda civic 1997 headlight adjusting" .Last edited by dr. d; September 24th, 2012 at 12:29 AM.
Tsikot Member Rank 3
- Jul 2004
- 1,540
September 24th, 2012 12:58 AM #5i think hindi properly installed yung bulb. Kasi usually when you change bulb minor adjustment lang or same lang level. check and reinstall bulb
September 24th, 2012 10:14 AM #6
yup sa kanan nga, ang problem nasa kanan lahat
dko na gets haha
sir nakita ko na yang adjusting screws, kaya nga po sabi ko kahit anong adjust ko hindi pa din mabago, alam ko na din yung vertical at horizontal kaya po kahit anong adjust ko wala pa din mabago.
yan din isa sa duda ko sir, actually nang nagpalit ako ng bulb, buong ilaw nya sa kanan lahat den nag moist pa yung kanang headlight ko, kaya ginagawa ko binaliktad ko yung bulb magkabila at inayus yun takip sa likod, ang na fixed ko lang is ung moist nya but the direction of the light is still in the right. and alam ko naman na mas malakas dapat ang buga ng ilaw pakanan kesa sa left para hindi masilaw kasalubong pero dapat pag inadjust ko yung horizontal screw nya sana naman nag improve ng konti but still ayaw pa din
September 24th, 2012 03:21 PM #7
try mo ulit ibalik yung lumang bulb sir then check mo kung ganon pa din... baka yung holder o lock nya ang problema... kungdi, baka yung bulb ang may problema...
- Oct 2009
- 2,271
September 24th, 2012 03:23 PM #8baka naman raspado na ung adjustment screw mo idol...
pag ung adjustment sa left & rigth hinigpitan mo..ang buga ==== pakaliwa,,,pag paluwag naman ang pihit o lefty..pa kanan naman ang buga..
pag naman adjustment sa pataas at pababa..pag hinig pitan mo...pa taas ang buga...pag pa lefty naman...pa baba ang buga...
September 24th, 2012 04:52 PM #9
pundi na sir yun dating bulb nya hehe
nice salamat sa info bosing, try ko ulet iadjust, basta kasi inadjust ko lang hehe.. pero wala pa din nangyari pero try ko yang post mo, bka this time effective na.try ko later, sir san ka ba nakatayo para malaman mo na pakaliwa ang adjust or pakanan, pagnakapwesto ka ba harap sa hood pag hinigpitan ko yung gear it means na papasok sa area ng car ko ang ilaw? thanks, sana hindi palyado ang gear kundi nalintikan na hehe
