Results 21 to 30 of 52
September 30th, 2010 11:01 PM #21
- Nov 2006
- 201
October 1st, 2010 08:44 AM #22mag sir, nakabili na ako OEM HOnda PSF sa Honda spa 550 a liter...thanks to all!
October 1st, 2010 09:57 AM #23
sir raine yes LTP pa din ako...
pag napunta ako sa casa kunan ko ng pic brake fluid ng honda ;)
- Nov 2010
- 21
November 2nd, 2010 10:54 PM #24Mga Sir pwede bang ipagawa ko na lang ang pag change ng PSF sa mechanic ng mga gas stations? plan ko kasi bumili na lang ng PSF then sa iba ko na pagawa. 700 kasi ang labor ata pag sa casa. TIA
- Nov 2009
- 456
November 2nd, 2010 11:19 PM #25
- Nov 2010
- 21
November 3rd, 2010 09:12 AM #26Thanks a lot CivicVTI, isa lang mechanic dun sa pagdadalhan ko sana, anyway baka sa honda ko na lang palagay kasi malayo ako sa speedyfix.
- Nov 2010
- 21
November 3rd, 2010 09:18 AM #27One more question pa po, currently atf po yung nakalagay as PSF ko, not sure kung kelan pa yun dun kasi kakabili ko lang nung car, how urgent po ba na need ko na siya palitan ng PSF talaga? I mean based on your experience or people you know, may nasiraan na po ba? ng gear box etc?
November 3rd, 2010 01:21 PM #28
yes sir flush your power steering immediately. buy 2 liters of honda PSF. Drain the fluid in your PS system
1. Jack up the front of the car.
2. remove the return hose from the reservoir and isaksak mo sa isang 2 liter bottle yung hose.
3. start the engine and let the fluid flow out. move the steeringwheel back and forth to evacuate the fluid in the rack and pinion.
4. Pour 1 liter of PSF into the reservoir continously and let it flow out of the return hose. This is done to flush out contaminated fluid.
5. Once no more fluid is coming out of the return hose turn off the engine and reinstall the return hose in the reservoir.
6. Fill up the reservoir with fresh new honda PSF upto the maximum level, then start the engine. Move the steering wheel back and forth 10 times while filling up the power steering reservoir to the maximum level. Do not overfill the reservoir make sure you dont go above the maximum level line.
7. Turn off engine and remove the jack.
- Nov 2010
- 21
- Nov 2006
- 201
November 4th, 2010 08:52 AM #30
Tesla Philippines
