Results 1 to 6 of 6
- Aug 2009
- 46
May 22nd, 2011 01:08 AM #1Last week lang nasa traffic light ako, then ng pag arangkada ko na feel ko wala ng lamig ang ac. That night pinatingnan ko sa isang ac shop sabi sira daw ang magnetic coil and clutch. Pero hindi ko pa pinagawa. Then kanina dinala ko na casa para dun ko na lang ipagawa. After four hours tumawag service advisor ang sabi sa akin stuck up daw ang compressor, so ang total na papalitan ay ang whole compressor assembly, including clutch and coil. Ang tanong ko po talagang ganun lang ba kadali masira ang ac compressor ng wala man lang indication na masisira na ito?
- Jul 2009
- 31
May 22nd, 2011 09:21 AM #2oo puede kasi ganyan din ang nangyari sa aking nissan frontier super lamig tapos bigla na lang nasira ang compressor. saka ang modelo ng crv na yan issue din ang madaling masira ang compressor kung babasahin mo sa forum dito, pareho ng modelo ang crv natin yung akin pag medyo mabagal na ang takbo ko humihina ang lamig.
May 22nd, 2011 10:23 AM #3
The compressor is one of the most overworked components in the air con system. There are many causes for it to break down. Regular cleaning and proper ventilation of the condenser would prolong the life of your a/c.
You should have looked for a reputable shop that could repair your compressor, the casa would recommend that you change the compressor. My Civic Vti which is 12 years old has not encountered a problem with it's compressor and it's still cold.
May 25th, 2011 01:17 PM #4
I owned the same model as yours. If you're planning to replace it with a brand new compressor, try visiting 1Rotary Aircon Supply at CAA Road, Las Pinas. They have in stock (if not, you may order) the original Keihin compressor for the 2005 CRV at a price of 11-12K. Then for the services I highly recommend CeeJay's Aircon Services at Zapote-Alabang Road just 300 meters away from 1Rotary.
- Aug 2009
- 46
May 26th, 2011 02:07 AM #5napaayos ko na sa casa, at napansin ko parang gumaan na ang driving, so probably matagal nang may diprensiya. napansin ko kasi dati parang mabigat i-arangkada at tumaas ang fuel consumption
- Oct 2011
- 22
August 21st, 2012 01:20 AM #6
Tesla Philippines
