Page 6 of 7 FirstFirst ... 234567 LastLast
Results 51 to 60 of 64
    Apr 2015
    #51
    Pards from my experience sa honda esi ko years back, pwede ka maglagay ng markings kung san nagmemeet ung bolt na may space for adjustment either forward o backward. Usually un ung top most na bolt. If i remember it right tatlong bolt yan sa distributor. pwede mo gamitan ng correction fluid na white or pentel pen para maibalik mo sa tamang pwesto. Madali lang gawin yan pards. Youl never go wrong naman sa pagbalik kasi yung grommet nyan going to the camshaft is male and female. Hindi mo siya maipapasok kung baliktad. Goodluck bro.
    #52
    errr...
    what happens when you return it the wrong way, then crank the engine and of course it won't start..?
    errr...
    #53
    Quote Originally Posted by paulomik View Post
    Good explaination bro.
    Sent from my Starmobile UP+ using Tapatalk
    #54
    errr...
    errr...
    May mating marks kasi po dr._d.
    Tipong hindi mo maisasalpak kapag mali pasok mo.
    #55
    Quote Originally Posted by johnlward18 View Post
    meron naman po ako tools sir pero kung sa knowledge sa engine konti lang po at d ako talaga ganun ka galing
    kumbaga lakasan lang ng loob sir .. hehehe.. thanks mga sir
    As for me, I myself also started as newbie in knowing things. As like others, we just all wanted to know how we can fix it. I am not also a pro nor a veteran mechanic working in an engine. Sa ganyan lang din ako natuto, sa pagsuri, may ingat sa kilos sa pag-gawa, systematic kunbaga.
    Jan 2011
    #56
    AH ganun ba sir .. yun nga ren po ang sabi nila eh .. lagyan ng marking ang kaso dko lam kung saan lalagyan .. yes sir tama tatlo bolt nga yan ang nakikita ko lang na may adjustment is isang bolt lang .. then yun dalawa is parang support lang thanks sir
    Jan 2011
    #57
    Quote Originally Posted by rodetor View Post
    ano ibig mo sabhin sir d siya papasok kung mali yun mating marks..
    Apr 2015
    #58
    Dun mo sir lalagyan sa may bolt na may adjustment kasi yun lang ang makakaapekto sa timing mO. Kung ndi mo malalagyan ng marking, either ma retard or advance timing mo. Kaya mo lang siyaa kailangang ma markahan para hindi ka mahirapan. To save time na din lalo at diy lang ang repair mo. If ndi mo siya namarkahan u can still start the engine naman pero hindi magiging pino ang andar ng makina mo. Either sobrang baba ng magiging idle or sobrang taas.
    Apr 2015
    #59
    You can see the top most bolt dyan ka maglalagay ng marking. Draw a horizontal line brad across the mating surface ng dist and engine mismo.
    Feb 2009
    #60
    The distributor drive for this car is idiot proof. It only goes in one way. To get the same exact timing after re installation, mark the distributor flange in relation to the mounting bore on the cylinder head with a scribe or you can use the witness marks to install it back exactly how it was before disassembly
honda city exi is for only 60k
