Results 1 to 10 of 81
    If im not mistaken the problem is the tranny itself. That is why Honda revertrd back to a normal torque converter automatic transmission on the next generation.
    Hopefully its fuel filter related like what you said. Goodluck sir
    if youre following the honda issues.. ignition coils are somewhat popular for older models...
    Jan 2018
    Many thanks Sir. Hoping din ako that it's just the fuel filter.
    By the way, meron bang fuel filter replacement lang na available in any local parts dealer. Namamahalan kasi ako sa original at Php 4,200 + labor pa.
    Jan 2018
    Quote Originally Posted by fortucsoner2018 View Post
    Just an update. Original Honda Fuel filter is Php1,800 lang pala my bad. The changing of the fuel filter did not solve the RPM issue. last Sunday i went to Evangelista and looked for ignition coils. 1 lang nakitang sira(the spring inside the coil was detached) sa harap. Isinabay ko na din ang change oil and oil filter pati na din changing of brand new front wheel bearings(2pcs). So far my Honda has greatly improved its performance. The jerking was minimized both forward and reverse movement, although personally hindi pa rin ako satisfied sa RPM (maybe paranoid lang ako or hinahanap ko yung dating performance nya 3 yrs ago).
    May nabasa ako to reduce the distance of the spark plugs.... anyone knows how can this be carried out or pukpukin ko lang sya ng martilyo?
honda city engine jerking
