Page 78 of 93 FirstFirst ... 286874757677787980818288 ... LastLast
Results 771 to 780 of 927
    Mar 2004
    #771
    Even with an ordinary battery, if one has 2 or more cars ... the CTek charger will pay for itself if just 2 cars extend their battery lives by a year or so ...
    Dec 2016
    #772
    Yes, and this may be good for you. However, that is not the case for me. My battery is priced at 15,000 so I really need to take care of it and hope to extend its life up to 5 years or more if possible.
    Now, consider buying a new battery every two years and compare it with a battery replacement of 4 years using CTEK charger. It has paid on its own.
    I think there are other brands that are not so expensive. I just posted the link and description when someone mentioned about this charger hoping it will help him and for others to consider it.
    Cars to share the physical setup sir? Want to see how it connects to the battery? Do you leave it connected or you just connect it once a day?
    Sent from my MI 5 using Tapatalk
    Jun 2004
    #773
    Gamit ko 10A 7 Stage automatic battery charger, around 3k bili ko over a year ago. Eto ginamit ko pang maintain ng battery, ngayon kelangan ko na palitan yung battery kasi medyo may leak na sa posts. Pero ok na rin kasi umabot naman ng 5 yrs yung batt.
    Pwede rin to pang charge sa deep cycle battery na pang solar.
    Tingin ko worth it yung price kasi kung ma discharge battery at least pwede ko charge at home, pag masiraan sa labas order na lang ako sa Motolite. Useful for me since pwede ko gamitin sa 3 cars namin. Usually once a week ko lang gamitin.
    Dec 2017
    #774
    Quote Originally Posted by kenken123 View Post
    I use it every night and leave it that way until I use the car. I don't see any problem if you leave it that way for a couple of days. I didn't use the supplied clamp but instead used the permanent connectors (I don't know what it's exactly called). It's plug and play.
    This is a very convenient way of charging your battery and leaving your hood in closed position. Just be mindful of it as you might forget you are charging it. This happened to me, almost. Now, I got the habit of checking it everytime before starting the car. Thank you, *walter and *travajante for this reminder.
    Dec 2016
    #775
    How do you charge the CTEK charger naman sir?
    Dec 2017
    #776
    You don't charge the CTEK, you plug it instead to your household outlet (220V). I think you are confusing it with a power bank jumpstart battery. This CTEK works like your cellphone charger but not as a power bank.
    Dec 2016
    #777
    I seeeeeee. Thanks sir. You're right, i thought it was a power bank. [emoji23]
    Dec 2017
    #778
    Quote Originally Posted by chris_d View Post
    For me, this is what I call an investment as mentioned earlier.
    For this reason why I have the portable jumpstart battery. I bought it in Ace hardware. I know it's expensive but I wanted to try it first before buying it so I didn't consider those from Lazada.
    Mar 2004
    #779
    Put a chair beside the driver's door with a sign reminding you to check battery charger ... also clean the quick connector socket from time to time as it will accumulate dust ...
    #780
    [QUOTE=kevinworld;2939131]Ctek is ok at first glance. Pero napaka mahal yon. Better buy a new battery nalang at that price
    Magaling nga daw yang CTEK ayon sa ibang forums.
    Yun lang dapat hindi na kelangan unless hindi mo ginagamit yung sasakyan ng madalas
    Yung case ng battery ng BR-V mukhang may nadadale talaga ng faulty.
    Lumalabas yung battery talaga may issue kaya imbes na bumili ng charger palit na lang ng battery kung lampas na warranty
Honda BR-V
