Results 1 to 10 of 16
- Sep 2009
- 44
April 6th, 2010 01:36 PM #1mga sirs,
good afternoon, ask ko lang po kung may idea kayo how much magpapalit ng crank shaft? pina check ko kasi sa honda they advise me to change the or repair the crank shaft dahil mauga at maingay yung crank shaft pulley. sa Honda kasi repair lang is 24k lahat. if ever repair lang may effect b?
- Jun 2004
- 1,311
April 6th, 2010 09:15 PM #3
- Sep 2009
- 44
April 12th, 2010 01:49 PM #4ph16 is my engine, not only the crank shaft was damaged also the crank shaft itself. that the reason why they will pull down the engine and repair the crank shaft. huh! laki gastos, what if I change to d16 or d15 how much will i SPEND?
thanks,
- Sep 2009
- 44
April 13th, 2010 12:11 PM #6sirs,
may idea ba kayo magkano camshaft na brandnew at magkano din sa surplus.
April 14th, 2010 03:04 PM #7
Last year nagpalit ako ng crankshaft and pulley sa civic 96 ko. Cost me 9k for the surplus crankshaft kasama na yung pulley and bearings sa evangelista. They took it from a ph16 engine with a busted engine block. Ganun daw dapat pag purchase kailangan nasa engine with oil pa wag daw yung mga nakasabit lang according to them. Labor for the installation umabot ng 10k kasi palit belts, mga seals, oil and painting ng engine bay, para na ring nag engine swap.
Pero if I were you I would go for the repair sa casa. Maayos ang warranty. Yung sa akin sablay pa nung unang kabit e tapos pag binabalik ko nagsusuplado na yung mechanic na buset. Kawawa tuloy engine
- Sep 2009
- 44
April 14th, 2010 06:51 PM #8sirs,
Kahapon tumawag sa akin ang casa Honda, di daw kaya i repair yung crank shaft ko, advise nila palit daw. ang estimate nila 69,000. parang sobra mahal na yata kapag nirestore ko pa old engine ko. limited kasi budget ko.
sirs, may advise ba kayo kung magkano ang surplus engine D15 or D16? at kung saan makakabili ng maayos?
thanks,
- Jun 2009
- 8
January 23rd, 2013 09:05 PM #9ganito nangyari sa akin nag pakabit ako ng timing belt sa kakilala lang ng cousin ko bumigay ung keyway na pinagkakabitan ng crankshaft natangal ung belt ng alternator kala ko ikakabit lang ulit ang belt, di ko na pinatingan ulit don sa kakilala ng cousin ko nawalan ako ng tiwala, buti na lang may nag recommend sa akin na friend ko, Jayson ung name nya senior mechanic sya sa honda qave, binaba makina ko para pa machine shop ung piyesa, tapos palit ng crankshaft.. ang galing binana ung makina ko almost 2 hours lang, tapos machine shop, dami pang inayos kame bumili piyesa, palit pati mga gasket, pati clutch ko may pinalitan kame, advise ka nya kung ano dapat pang palitan.. good thing malapit lang ako sa Honda Rizal... 2 days lang ginawa dahil intay pa kame sa machine shop sabi nya nga kaya daw ng 1 day medyo naabala lang sa machine shop pati problema ko sa RMP na mataas solve nya pinalitan nya ung servo daw yata un bumili kame surplus lang 2k somewhere in banawe.. kaya lang gabi lang sya pede gumawa kasi nga pumapasok sya sa honda q. ave pag labas nya tsaka lang sya makaka pag service.. saturday and sunday ako nag pa sched ng service nya.. magaling yung jayson na gumawa mga sir two thumbs up.. mag 3 weeks ko na gamit wala naman problema kada sunday uwe ako bulacan., complete ng gamit pati mga timing lights etc... just incase meron kayong problem basta Honda text nyo sya ito number para makatulong din sa mga kagaya natin na nag hahanap ng maayos na mechanic.. 09997124337 - 09162521211 - jayson
Tesla Philippines
