Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Apr 2012
    naka harness na ang headlight ng honda vti 96 pagbili ko.
    plano ko mag hid.
    need pa ba hid kit or hid bulb na lng??
    need pa din ng kit... dahil wala kang ballast.
    Oct 2009
    matanong ko lang idol ano po ba ung harness na tinatawag..
    ito ba ung retofit projector...
    kasi ung sa akin HID lang walang harness kaya medyo sabog ang buga..
    Quote Originally Posted by jaypee10 View Post
    the harness refers to the wiring per se.
    the projector refers to the lens where the bulb will be put in place.
    May 2011
    Quote Originally Posted by 1D4LV View Post
    +1
    harness refers only to the "wiring" upgrade (+ relays & ceramic sockets) - which can 'stand' a higher BULB wattage.
    if you want HID, get the set/kit
    1. Ballast (check wattage & housing - dictates na price, eg slim ballast + higher wattage)
    2. Bulb (if H4, meron Hi & Lo parehong HID, meron din Hi - halogen, lo - hid)
    temp:
    3000k -4300k yellow
    6000k white
    8000k bluish white
    * and up (purple?)
    with this rainy season, a good pair would be yellow on fogs + white hid (kasi bulag ka sa ulan+asphalt road)
    Advantage naman sa projectors: buo ang bato at hindi sabog (kawawa kaming mga kasalubong mo in case)
    hth
    projectors hindi lang advantage, its a must.
    pag walang projectors dapat hindi gumamit ng HID.
    Jul 2010
    hindi rin basta naka projector eh ok na gumamit ng hid, imho meron 2 types of projectors, 1 is designed really for hid &
    the other type of projector is designed for halogen bulb used, this type of projector will still give glare to the incoming motorists when installed with hids..to solve this glaring issue the projector must be retroffited to give a proper cut off..hth
    Quote Originally Posted by flakez View Post
    Tama! Pero dapat maganda rin yung aim ng projectors. Naka-projectors nga taas naman ng aim.
    Tsaka meron din mga projectors na cheap lang... minsan mas panget pa yung buga neto sa stock reflector bowls. So, halogen ka nalang kaysa mag-pilit ka ng HID + cheap projectors Hehe
    Apr 2012
    to wrap this up..ano po ba magandang hid?specific details?gusto ko yung lumalaban sa may nakasalubong na hid.kc nakakabad trip na hindi mka laban yung stock lights ko.tnx mga master...
    ano nga ba ang average life span ng mga hid?
    iyong sa amin kasi stock/oem hid ng fd and after almost 6 years it's still doing fine
Question: Hid
