Results 1 to 4 of 4
    Jun 2012
    Guys, pwede ba e pag mix ang "honda anti-freeze coolant type2 (blue)" and "honda coolant type1 (green)"?? ryt now coolant type 2 (blue) ang nasa reservoir tank ko. gus2 sana mag top up ng coolant kaso coolant type1 (green) lang ang available sa honda casa. Thanks.
    Oct 2009
    Quote Originally Posted by mido_ban View Post
    pwede na yan pareho lang naman silang anti freeze coolant ,ang mahalaga may coolant ka.
    pero kung gusto mo naman i drain mo na ang dating coolant mo at palitan mo na ng nabili mo sa casa,para lahat bago na..
    kailan kaba huling nag palit ng coolant..
    dapat hindi.
    pero w/ honda phil being stubborn re bringing in the type 2 coolants, limited ang options natin dito.
    kaya ako bumili pa ng type 2 coolant from a fellow fd owner who brought in a whole bunch of them from the usa for his personal consumption and for those who are in need of them
    anyway, ito ang pinaka-sound explanation na-encounter ko as to the importance of using the type 2 coolant
    honda type 2 coolant is formulated specificially for all aluminum engines. some antifreeze, although labeled as safe for aluminum engines, is not compatible with hondas aluminum alloy. this is especially prevalent in the elements with clogging heater cores(it's only about 1500 vehicles). the coolant used in certain vin specific elements was contaminated from the factory (although honda does not admit it is at fault) and caused massive corrosion build up in the heater core and radiator. (replacing that heater core means removing the entire dash assembly btw)
    most domestic coolants have abrasive silicates and borates which adhere to the water pump seal causing premature seal failure and leakage down the road. this silicate tends to settle and collect in the coolest parts of the cooling system. this causes crud to build up and eventually block coolant passages blocking coolant flow and reducing cooling capability.
    borates tend to cause pitting in the cylinder head.
    keep in mind silicate inhibitors are difficult to stabilize - this reduces coolant shelf life. silicate was added to coolant for it's aluminum protection characteristics, but long term durability was never tested. other coolants simply don't contain the combination of additives needed for long engine life and water pump seal lubrication.
    honda coolant does not use silicate because of the reasons listed above. although it has aluminum corrosion protection characteristics, it is not heathly for coolant seals and breaks down and collects too readily. honda uses an organic corrosion inhibitor instead of silicate. corrosion simply does not occur in the cooling system with honda coolant.
    i have first hand proof of this by doing countless t-belt/water pumps and loving the lack of problems with the cooling system. however, when vehicles on their 2nd timing belt come in(after having the first t-belt/water pump done aftermarket) i find leakage from the water pump seal and corrosion build up int he radiator tubing.
    if you insist on using aftermarket coolant be sure it does not contain silicate or borates and that it claims it's specifically for all aluminum engines if not honda/acura or import engines only. that will be your best shot at prolonged protection.
    Anti-Freeze - Honda-Tech
    Hindi naman ako nagproblema nung pinaghalo ko, bought the car brand new 2008, hinaluan ko nung mga 2010, until now hinahaluan ko pa din, pero di naman ako nagkaproblema sa cooling system, wven our other car, more than 10 years old na ok pa din.... Fingers crossed nga lang 😱
Can i mix "Honda anti-freeze coolant type2 (blue) and "honda coolant type1 (green)"?
