Results 1 to 10 of 10
    Dec 2012
    Pinapalitan ko outside the casa ang engine support and they had to disconnect the battery. Do I need to bring to honda for a reset? Thanks
    the fact na inalis na batt eh na-reset na yan
    Jan 2011
    Quote Originally Posted by roycruz View Post
    I do not know if this is still applicable with Honda, but it used to be that it was necessary to temporarily connect a little (flashlight) battery with a jumper to the radio before disconnecting the battery, otherwise the radio would not work afterwards. This was an antitheft feature.
    Ciao!
    Uncle Nick.
    Dec 2012
    Thanks parang may nabasa kasi ako dati na dapat dalhin sa honda after ireconnect ang battery.
    Dec 2003
    I DIY ecu reset my civic 2004 every time dinisconnect ang battery terminal, otherwise I get rough idling. Na search ko Lang sa club7thgen how to do it. Helps a lot!
    ako din. after disconnecting the battery, i do the idle learn procedure. nabasa ko lang din dito sa tsikot.
    Dec 2012
    Quote Originally Posted by Mannyx View Post
    Napansin ko din may konting rough idling pa rin after changing the engine support possible kaya na yun ang reason? Although may nabasa din ako that the ECU will learn by itself by driving for few days. Will observe na lang if it improves next week. Thanks
    Jun 2008
    alam ko lahat ng car model year 2000 up kailangan may back up power before replacing the battery....
    para hindi mawala mga settings niyo.... esp, american cars.... eg ford, chevy...
    Oct 2011
    hassle din pala when you disconnect the battery.
    Dec 2012
    Just realized sa stickies ko pala nabasa yung pag recalibrate.. Will try later :-)
Battery disconnected -- computer reset needed?
