Page 340 of 341 FirstFirst ... 240290330336337338339340341 LastLast
Results 3,391 to 3,400 of 3405
    Apr 2016
    #3391
    Quote Originally Posted by MasterHepburns View Post
    What are your other brake pad alternatives? Mine already squealing and need to replace(third time) a new one . I want to go for a change and a bit cheaper than the OEM this time.
    Nissin NPO-152W-SA (with shims)... Nissin din disc brake systems ng GK natin... you can't go wrong with it...
    Apr 2016
    #3392
    medyo matanda na GK natin mga sirs/maams...
    any rusting issues?
    apart from the known "kulubot" style rust sa mga doors, pansin ko na din sa mga wheel wells ko bottom part near the side skirt line...
    8 year old GK here, 92k kms mileage.
    Feb 2015
    #3393
    Hanggang anong size ng tire kaya ang pwede sa GK RS?
    Yung hindi sasayad sa wheel well kahit naka-sagad yung liko.
    Yung wala na din babaguhin sa setup, basta isasalpak lang.
    Ang size ng stock tires ngayon ay 185/55 r16.
    Gusto ko sana ay yung mas mataas kahit konti.
    Thanks!
    May 2016
    #3394
    Quote Originally Posted by bim27142 View Post
    any rusting issues?
    so far wala pang kulot yung stock paint, other than gas gas. wala pa akong nakikitang visible rust sa body. I have removed and cleaned the seats.. so far walang visible rust or evidence of leaks during that process/activity.
    sa disc brake, definitely minsan pag naulanan at di nagamit ng matagal, nagkakaron ng rusting, but after few use nawawala naman.. i believe its normal naman.
    yung pamumuti ng mga trims is visible, so planning to buy trim restorer na acrylic base (eg. turtle wax graphene stuff), currently using yung old type na turtlewax trim restorer.
    7yrs na yung jazz 2016 ko.
    May 2016
    #3395
    Quote Originally Posted by makelovenotwar View Post
    Thanks!
    yung last na nagpalit ako, depende sa profile ng tire.. but if you get wider mags, possible to get wider profile na tire.
    205 yung sabi sakin sa minerva. though i stick with stock size na kumho nung nagpalit ako ng mags(reason: para mas madaling linisan)
    Apr 2016
    #3396
    Quote Originally Posted by pongscript View Post
    thanks sir sa feedback! appreciate it.
    ito yung sa akin... i've seen worse from some of my GK owner friends din... wheel arch yata pala tawag dito...
    Click image for larger version.
    Apr 2016
    #3397
    Thanks!
    critical din ang offset ng mags... at least +42 yata dapat para iwas rubbing... kung gusto mo medyo malaki/mataas, 205/45r17 yata bagay dyan...
    205/50r16, 205/45r17, 215/40r17
    Feb 2015
    #3398
    Pasubukan ko yung 205/50r16.
    As much as possible ay ayoko sana galawin yung offset. Tapos stock mags pa rin ako.
    Basta ang goal ko ay tumaas kahit konti man lang para naman makaiwas sa pagsayad nung pang-ilalim.
    Thank you!
    Feb 2024
    #3399
    Thank you!
    Are the tires due for replacement? If not and the objective is to raise ground clearance, have the shocks/coils checked to see if they need to be replaced.
    Feb 2015
    #3400
    Quote Originally Posted by Motortrend View Post
    Yes, due for replacement na ang 4 tires.
    Will look into the shocks na din para isang trabaho na lang.
    Thanks!
All new 2014 Honda Jazz (3rd Gen)
