Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    1st question may available ba na projector lamps para sa model natin??? kung meron saan nakakabili at magkano?
    2nd question any available body kits?
    3rd question may club ba for honda city 1997 exi model?
    Aug 2010
    Ako rin naka honda city 1997 exi, ask narin po dun sa passenger side sa likod ng floor sa carpet pag tinatanggal ko basa, hindi ko alam kung saan nanggagaling yun, sino na naka experience ng ganun?
    Oct 2005
    alam ko parang may club yan 1st gen Honda City, parang tropang SX8 ata pangalan..
    for question number 2, OEM ata may lumabas sa Honda before. IMO, it is a nice looking body kit.
    Aug 2007
    good day po.
    asking po on my honda city type z vtec. biglang di gumana speedometer ko then habang tumatakbo umilaw check engine. i tried huminto then patay engine and start again, nawala ilaw ng check engine pero habang tumatakbo umiilaw ulit. ano kaya reason. ok naman takbo wala naman ako napansin sa andar ng car.
    Jan 2009
    Quote Originally Posted by dennisshane View Post
    good day po.
    A/T? If it's a speed sensor problem and not with the instrumentation (ie. gauge cluster or CAN bus communication issues), then that would throw off the ECM/PCM. The latter relies on the current vehicle speed, RPM, engine load, among other parameters, to make decisions on when to shift. But this is just a guess. It's prudent to have it scanned so it can hopefully lead you to the root cause.
    Aug 2007
    Manual po, vtec engine. di naman umiilae check angine dati un lng nung di na gumana speedometer ko once tumakbo ako ng medyo malaya umiilaw check engine. pero once off then start, nawawala pero imiilaw ulit once tumakbo na ako ng medyo malayo. may kilala po ba kau na nag scan dito sa cavite?
    Jan 2009
    Try mo sa FB Marketplace kung meron malapit sa inyo na repair shop na may scanner. Wag lang "clear codes". Dapat mahanap nila root cause.
    Malawak ang Cavite, sorry no idea kung kanino ka dapat pumunta. Although may mga Rapide sa Cavite. Use best judgment nalang.
    Feb 2024
    good day po.
    Just a tip. Next time, no need to spam different threads. Stick to one and be patient.
    Aug 2007
    This is noted
    Aug 2007
    Baka po may recommended kayo shop dito sa cavite na nag scan ng check engine. ty
All about honda city 1997
