Page 267 of 530 FirstFirst ... 167217257263264265266267268269270271277317367 ... LastLast
Results 2,661 to 2,670 of 5300
    Nov 2017
    #2661
    Thanks for the reply.
    Glass coating keeps your car shiny and protects it from swirl marks and hairline scratches, so basically it has the same effect as regular waxing.
    Pros - you just do it once and you're done. Cons - expensive, and tbh it doesn't look that different from a car without glass coating.
    Thank you Sir StockEngine.
    as the name implies. detailing or cosmetic detailing or automotive detiaing is improving appearance inside and outside. paint detailing's goal is making the paint look perfect.
    protection via wax, sealant, coat, film are different ways to protect the detailed vehicle.
    best free photo upload sites
    #2662
    I noticed that gas CRVs use the Toyo Proxes R45 as the OEM tires, while the diesels use Michelin Primacy 3ST.
    I wonder which is the better performing tire between the two. There aren't much reviews online for either.
    Jun 2012
    #2663
    re knocking sound, I had that prob before on my gen 3. And yes it is because of the EPS.
    But as you stated kahit hinigpitan na, the toktoktok sound is still present, did they already check the top shock mount?
    Oct 2017
    #2664
    Quote Originally Posted by sabawballs View Post
    The SA didn't enumerate the parts they've check bro but I think they checked na the major parts that can probably cause the knocking sound. Nabubugbog na din kasi yung car kakabaklas ng parts and then test drive ng paulit ulit kaya they advise me na much better to wait na lang muna sa feedback ng planta regarding this problem. May hawak kasi ngaun ang planta na ganitong case din. Hopefully ma-figure out ng planta agad what's causing the knocking sound nakakairita kasi talaga yung bago ang car mo tapos may narrinig ka kumakalampag.
    Jun 2012
    #2665
    Quote Originally Posted by Bokyoo View Post
    agree with you 100% na brand new ang sasakyan sabay may knocking issues agad. Hopefully mahanap talaga nila what is causing the knocking issue.
    #2666
    The V variant has Dunlop Sportmaxx's. So many OEMs for a single model hehe.
    *Bokyoo
    Been getting some suspension noise up front as well. You can hardly hear it as NVH insulation is top notch, but it is there. <1000km.
    Oct 2017
    #2667
    *Bokyoo
    Yes sir Wh1stl3r mine started the same you can barely hear it dati kaya i just ignored it. Pero ngaun audible na talaga sya lalo na sa rough roads and minsan maski sa smooth pavement naririnig ko na din sya. Kaya pag medyo naiirita na tenga ko i just turn on the music
    Sep 2017
    #2668
    mga sirs,
    magkano po kaya aabutin sa delivery charge kapag ipapadeliver yung sasakyan from bulacan to baguio?hehe
    o mas ok po na kunin na mismo sa dealer,
    Sep 2014
    #2669
    sigurado yan icharge ka nila sa NLEX, SCtex, TPLEX
    Dec 2017
    #2670
    Quote Originally Posted by Ronronzards View Post
    mga sirs,
    usually walang charge. sagot na ng SA yung delivery, syempre commission nya rin yun. yung nakausap ko sa ilocos willing nga ibaba rito sa metro manila.
2017 Honda CR-V Turbo and 7seats
