Results 1 to 5 of 5
- Jun 2007
- 3
June 13th, 2007 08:59 AM #1Mga Sir,
I just got my first car (im so happy), 2nd hand Lancer EL '92. Yung model pala na un hindi power(steering,window...) Pwede ba siya ma-upgrade to power steering and window? Saan po kaya pwede pagawa at mga magkano kaya gagastusin?
Thanks in advance and more power!
June 13th, 2007 09:10 AM #3
jhune,
try browsing www.mymitsuph.com or better yet sali ka sa forums. there's alot of info there regarding your query.
as per your question, yes it can be converted to power steering, any competent mechanic can do that, if you're near or from San Juan you can contact Ray Sarol 09209252290, he's my friend mechanic. Text mo muna si Ray to set an appointment.
Same with your windows it can be converted to power windows too.
Gastos? I have no exact figure, but ballpark figure for converting to power steering can cost you somewhere around 10K or more, inclusive na siguro dyan ang labor, again this is just ballpark figure. Kung makahanap ka ng mas mura then good for you.
HTH
June 13th, 2007 03:10 PM #4
Sana you get the Glx or Glxi. But it can be done naman. Mura na mga parts nyan by now. Pero you have to replace the whole panel para sa power windows.
- Jun 2007
- 3
June 14th, 2007 03:14 PM #5Maraming maraming salamat po sa mga replies.
Isang question pa po. Yun ignition key is different from door lock key, possible ba na mapapalitan ko sa mit yun ignition at door lock para iisa na lang un key? Or pwde rin kahit sa hindi mit serv center.
Thanks po uli.
