Results 1 to 10 of 15
March 11th, 2004 01:20 PM #1
sa mga nagkaroon na ng pizza pie.. gusto ko lang sanang malaman ang specs ng 97 GL. horsepower, engine specs, etc. nawala ko manual nung auto na nakuha ko. sa rehistro, 16valve sya pero 1500cc? tama po ba yun? thanks sa mga sasagot.
March 11th, 2004 02:47 PM #3
ganun ba? kala ko pa naman 16 valve.. hhhmm.. anong difference sa performance (i mean, bilis) kung maglalagay ako ng headers/mufflers?
March 11th, 2004 02:53 PM #4
there would be minimal improvement, i think. i think its better if we should ask the opinion of other guys here. medyo ala akong alam sa enhancements eh. mr. stock ako eh.
March 11th, 2004 03:04 PM #6
like what Mr. Happy_G said very minimal
if you're really serious about adding power to your ride you can either:
1. buy this http://www.clubmitsuph.com/index.php...iewtopic&t=424
or
2. buy a surplus 4G92 SOHC from a Pizza GLXi then force induce it or have it ported and polished.
Your choice
Tsikot Member Rank 3
- Dec 2002
- 551
March 12th, 2004 02:26 PM #7engine model : 4G15
type : SOHC 12 valve, gasoline
fuel system: variable venturi carburetor
displacement : 1,468cc
bore x stroke : 75.5 x 82.0
compression ratio : 9.0
max. output kw(ps)/rpm din net : 65(88)/6000
max. torque : nm(kg-m)/rpm din net : 120(12.2)/4000
top speed 180kph (M/T) - 170kph ( A/T)
brakes front : 13" ventilated disk
rear 7" leading and trailing drums
brake booster 9" master vac
hope this helps you : )
March 12th, 2004 05:33 PM #8
mas pangit nga yung pizza GL kesa itlog GLi. at least yung itlog GLi naka-EFI na, with corresponding higher output.
- Mar 2007
- 2
March 5th, 2007 11:58 AM #9kung pangit pa po sa inyo ang pizza gl mag upgrade nalang po kayo tapus bilhin ko nalang yan auto mo
- Mar 2007
- 1
March 5th, 2007 02:05 PM #10Mga sirs,
Newbie po ako sa Mitsu. I had a current car pero Nissan. I was encouraged by my colleage here at work to buy a 97 glxi mitsu. I'm considering that option with my budget of Php250K.
could anyone po mention again the advantage of this car over the other rival models in that area?
Advance thanks for the replies.
Tesla Philippines
