Results 1 to 9 of 9
- Jan 2003
- 41
March 8th, 2003 04:05 PM #1Mga tol, di ko na alam kung ano papatingin ko sa kotse ko, HELP!!! Idle is unstable, kapag naka-neutral ako up and down yung RPM. tapos kapag tumatakbo, kapag nag-shift gear ako, biglang bagsak ng RPM. Here is what I had done so far: Tune-up, change oil, cleaned the carb, had idle checked (pero nagbabago pa rin), changed sparkplug to a platinum one, had my timing belt changed, also changed Cylinder gasket. Di ko na alam ang gagawin ko mga tsong, need your HELP BADLY. Thanks.
March 8th, 2003 04:37 PM #2
baka may connection din yan sa aircon mo bro. ganyan din nangyari sakin before. patingin mo rin. good luck!
- Jan 2003
- 41
March 8th, 2003 04:45 PM #3Bro, ano possible sira sa aircon? Actually, sira yung Idle up ko and sa monday pa lang darating yung binbili kong idle up. Pero kahit di naka-aircon ganun pa rin e.
March 8th, 2003 04:49 PM #4
kasi i had some pulleys and belts changed dahil erratic yung idling ko dati eh...
after that ok na!
- Jan 2003
- 41
March 8th, 2003 05:50 PM #5Parts ba ito ng Aircon system, my car is only an 89 Corolla. Thanks bro, bago lang ako e. =)
March 8th, 2003 07:38 PM #6
yup i think so kasi konektado din sya sa cooling coil eh
gurus help pls! :mrgreen:
March 9th, 2003 08:26 PM #7
Check if you have a vacuum leak somewhere. Also with the carb, maybe your carb needs to be overhauled or cleaned, expecially if you have not done so before (not yung clean with some carb cleaner but to be opened up and remove the buildups that have went the bottom) already. This should not cost much IMO.
- 290
March 10th, 2003 04:21 PM #8dalhin mo na sa casa bro, toyota pasong tamo okay and look for Jess Teran.
- Jan 2003
- 41
March 11th, 2003 06:15 PM #9Gusto ko nga sana sa Casa sir e, kaya lang malayo, kasi dito pa ako sa pampanga. =) Napaayos ko na nga pala kahapon, dito sa Bolt-on, para ding Casa ito sa pampanga. Inayos yung timing niya, may inadjust sya sa likod ng carb, then ayos na ulit. Tama kayo, sa vacuum may problem din. kaya lang di pa totally ayos kasi yung idling switch ko, di gumaganang mabuti, di nagrerelease ng hangin kaagad. kaya lang wala pang available na Idling Switch sa surplus e, hintay pa ako ng 1 week. Thanks sa inyong lahat.
