Results 11 to 14 of 14
February 13th, 2006 03:23 PM #11
Yun nga yata... not sure per engine kung ano yung exact... depende rin yata sa ambient pressure. Last time I did this, 110-112 yung engine na na-test namin. Malakas pa yung hatak niya, naninigurado lang ako dahil surplus.
If your engine starts to lose compression from blown piston rings or a leaking gasket, usually, the effect is stronger for cylinders on one side or for one particular cylinder.
February 13th, 2006 06:47 PM #12
There's also a wet and dry procedure for this to determine what part can be blown.
February 13th, 2006 09:33 PM #13
afaik there's a different compression tester for diesel and gas engines..
February 13th, 2006 09:42 PM #14
mga sir tama ba, pwede rin ma-test ang compression when downhill, kapag may engine brake at first gear, kapag kayang kontrolin ng makina ang pagbaba mo ibig sabihin e ok pa sya...
Tesla Philippines
