Results 1 to 7 of 7
    Aug 2007
    I saw a car toyota corona '91 GL (2.0)
    - All power
    - MP3
    - keyless entry
    - A/C
    - white body
    very fresh po cya at makinis
    and selling for 90k , and im planning to get this one
    nakita ko na rin makina nya at tuyo cya / malinis
    Any advice po?
    Quote Originally Posted by noynoy View Post
    - All power
    - MP3
    - keyless entry
    - A/C
    - white body
    Any advice po?
    Assuming you don't know the seller, it would be wise to have the car's registrations checked for any problems.
    Next is to have someone who knows about cars to go with you and check out the car. Make sure there is no fluid leaks anywhere. Ask questions regarding the car's history like any major accidents. Try to compare notes like if the seller mentioned no major accidents but you can spot a welded/replaced structural section, you might want to walk away.
    Do a test drive. Make sure nothing squeaks or grinds. Test the a/c if it runs cold. Try to make your test drive on a sunny day and near the middle of the day to check if the a/c is running ok. Drive over small bumps and humps to check if the suspension feels ok. Accelerate and brake hard to see of the engine & brake systems are fine.
    Aug 2007
    How about gas consumption? Any idea
    tnx
    Sorry sir, I dont know the FC...
    But dont expect Jazz-like figures/Hybrid figures...
    Basta well maintained vehicles will give you good FC performance.
    iam3739.com
    Nov 2006
    Looks can be deceiving ...
    Try test driving it to have the feel of the car, bring a good trustworthy mechanic to assess the car.
    afaik, the FC ng Corona 2.0 is around 5-6 kms/l city, around 8 kms/l highway. yung kumpare ko, meron nyan.
    Aug 2007
    gas consumption .. sa tingin ko malakas .. knowing that its a 2 liter engine ...
    Dont be deceived by the looks .. naghanda na yung seller to make it look good para mbilis mabenta .. di bale na madumi basta maganda performance .. maganda nga pero bibigyan ka naman ng sakit ng ulo instead of relief .. magsama ka ng mekaniko na trusted mo so he can check it all up .. or better bring an appraiser with you
Help Need Advice
