Results 1 to 10 of 20
- Feb 2007
- 9
February 16th, 2007 12:54 PM #1Just got my Honda Civic 2.0SL Nighthawk Black this week complete with the Paddle Shifter -- Wohooo!!
Any info on the detailed specs of the engine ?
February 16th, 2007 01:16 PM #2
Wow! congrats to your new ride
. kakainggit! grabe ang ngiti mo sa pic sa dulo ah, hehe.
February 16th, 2007 01:21 PM #3
2.0 DOHC 16V I4
Maximum Output (bhp * rpm) 155 * 6000
Maximum Torque (Nm * rpm) 192 * 4200
Fuel Type / Recom. Octane Gasoline / 95~
Fuel System / Aspiration i-VTEC, EFI / NA
February 16th, 2007 01:42 PM #5
152 hp... supposedly dynos at 125-130 whp on the rollers, which is terrific for an AT car. (mine dynos at 132-137... still going to confirm when I get my mods done).
Lacks a little torque, but really lively once you get it revving. Love the paddle shifters, as they'll let you do things most manumatics won't.
February 16th, 2007 01:52 PM #6
K20A3? still? it should've been the true K20A (type r) by this time right? i don't know why HCP doesn't want to bring in the true blue K20A or at least the K20Z3 (Si)
- Feb 2007
- 9
February 16th, 2007 03:53 PM #7What is the difference between the K20A and K20A3 ? From the pictures they look the same. Is it tuning ? They are both 2.0 liter engines with almost the same parts. Or is it just the ECU ?
I am still experimenting with the paddle shifters cuz i am still heavily dependent on the the shift indicator found at the lower display. One fundamental flaw was they did not put the shift indicator on the upper display where it is much much easy to look at if you want to keep your eyes on the road.
February 16th, 2007 04:26 PM #8
It's not just the ECU and Tuning differs the K20A VS. K20A3.
If that is the JDM civic engine (non type r) then it is a K20Z2 it's the same as the K20A3 where the ivtec system is "only" on the "intake" cam and functions as a 12 valve engine when on low rpm mode and opening only one intake valve so that the air swirls for better combustion. The ivtec system on this engine is dedicated to fuel economy in mind. Unlike the K20A/A2/Z1/Z3/ the ivtec system allows the motor to run in 16 valve mode all the time and when it engages, its on both the intake and exhaust rockers, and opens all 4 valves even more at high RPM.
February 16th, 2007 10:35 PM #9
e ung sa UDSM na FD-SI, anu difference sa specs ng engine nun over sa local nating k20a nanakaabit sa local nating FD??
(aside sa 6-speed manual tranny and red guages w/ SI printed on it...)
February 16th, 2007 10:51 PM #10
yung us na 2.0
197hp*7800
redline is 8000rpm
ang laki yata ng deperensya
Tesla Philippines
