Results 1 to 6 of 6
- 96
April 17th, 2006 04:25 PM #1I have got a problem...recently nawalan lamig car ko, then I ask a technician to check, kulang daw freon, I had some freon loaded, lumamig naman (morning non)..
but recently(AFTER 1 DAY), pag mainit di na kaya at mainit na ciya,,napansin ko lang kapag mainit...
yung fuse niya (for the AC compressor pulley, yung sa edge ng compressor) umiinit, at napapatid fuse(7.5 rating), ginawa ko nilagyan ko wire to bypass..
pero pag matagal na parang yung pulley nag saslide, di continous ikot...
pag binubuhasan ko tubig yung condenser (yung tabi radiator, na parang radiator din, lumalamig ang AC..
what could be the problem?
sa fuse ba?
sa pulley ba?
or sa condenser dahil barado daw (sabi mechanic)
please help
init pa naman..
April 17th, 2006 04:59 PM #2
If I remember it right, nabasa ko din dito, kung binuhusan mo ng tubig tapos lumamig ung singaw, it would either be the aux fan or the compressor. Not sure on the last one though.
Intay na lang natin reply ng iba.
April 17th, 2006 05:29 PM #3
Dati nanyari sa akin na ganyan, may leak yun evaporator ko. Had it replaced. 4K. If it weren't for a leak, baka makuha na linisin lang evaporator. Usually, dumi lang nun.
April 17th, 2006 07:05 PM #4
Maingay ba compressor mo? Baka malapit na bumigay? Pero I'm not sure if that will explain the fuse being tripped. For me, kapag may mga fuses na natri-trip, electrical na agad ang hula ko.
Check mo if you're leaking coolant, may maliit na window na you can peek into. Kapag maraming bubbles ibig sabihin kulang na naman coolant mo, therefore may leak ka nga.
April 18th, 2006 03:07 AM #5
Marami pwde dahilan..
1. yong pulley dapay continous ikot, baka belt dapat nang palitan, or the bearing may tama, so mahina mag pump ang compressor resulting to poor coooling.
2. Pwede ring barado na ang condenser mo kaya na high pressure then trip off the compressor. at this stage no cooling at all.
3. Pwede ring auxillliary fan ang problem, mahina na ikot maybe bearing/bushing or winding problem hindi na nya mapalamig yong condenser kaya high pressure din and then trip off the compressor.
4. Posible din na na over charge din ang freon resulting to have high condensing pressure and high current drawn bt the compressor. Mis-trouble shooting. baka yong problem No.1 yon talaga sakit but mali yong solution that creates another problem.
5. Bring to reputable shop to observe and determine the real caused.
hope it can help. good luck...
4.
Tesla Philippines
