Results 11 to 20 of 23
September 12th, 2005 09:16 PM #11
mas ok nga gated actually, the only gears wherein you "shouldn't" need to look at is N and D, the rest you have to anyway (except for P and L/1, I guess since dulo sila).
The gate takes out the button in straight shifters.
In straight shifters, you don't have to press the switch from R-N-D
Tsikot Member Rank 3
- Jul 2004
- 1,540
September 12th, 2005 09:29 PM #12Tama mga nagsabe na mas madali ang gate. I use an Optra with a gated shifter and it's easier to use it without looking at the shifter or indicator compared to conventional matics. Nakabisado ko na un pwesto. :D hehehe. Ang ginagawa dito para mag reverse or shift to park i ppress down mo lang un shifter instead of having a button at the side or on top.
September 13th, 2005 07:30 AM #13
Originally Posted by glntVR
September 13th, 2005 10:10 PM #14
Benzes have been using gated shifters for a very looooong time. Yes, the are easier to use (as compared to the non-gated ones in our other vehicles). And you don't have to push a button.
September 13th, 2005 10:22 PM #15
and it appears from the outside that you're driving a stick instead of an A/T ... kunyari :-)
September 14th, 2005 12:27 AM #16
sa non-gated AT shifters is it ok to always press the button when changing gears? or should you stick what is stated sa manual na on certain gears lang?
also for gated AT shifters, mahirap ba masanay without pushing the button? and instead pushing down the shifter itself?
September 14th, 2005 12:31 AM #17
There is nothing to push on a gated shifter. You just work it through the gates.
You can always push the buttons on non-gated ones. Walang masisira pero nakakapagod naman yun sa daliri mo kung pwede namang hindi na pindutin na diba.
September 14th, 2005 12:34 AM #18sa non-gated AT shifters is it ok to always press the button when changing gears? or should you stick what is stated sa manual na on certain gears lang?
September 14th, 2005 12:37 AM #19
Yung MDX ko dati gated ang A/T shifter. Safty feature daw sabi sa MDX club pero minsan nao-over shoot ko pa den pag gusto kong mag down/up shift manually. Depende siguro sa positions ng gears sa shifter. Yung sa MDX kasi nasa baba lang ng 4 yung 3rd gear kaya minsan nao-over shoot ko yung 4th gear.
September 14th, 2005 09:46 AM #20
column mounted shifters of the crv can also be considered as gated shifters sideways
Tesla Philippines
