Results 1 to 7 of 7
    Jan 2004
    Anu-ano yong pagkakaiba ng mga ito (in terms of engine, valves, features / accessories, etc)?
    Corolla (89 ba? ++)
    Corolla (93?++ models) -- XL / XE / GLi
    Lancer (93?++ models) -- EL / EX / GLi / GLXi
    Sentra (Series 2) -- may mga models din ba to?
    Sentra (Series 3) -- (EX, SuperSaloon)? may mga models din ba to?
    Sentra LEC -- models?
    Salamat.
    Yung 1989 na Corolla may 1.3 at 1.6 engine. 2E yata yung 1.3. Hindi ko alam engine code nung 1.6 pero carb sila pareho.
    Lancer is powered by either a 1.3 (EL), 1.5 4g15 in the GLi, and 1.6 4g92 (?) in the GLXi. EX models are basically the same as EL pero released ang mga ito alongside the newer 'pizza pie' lancers of 1997.
    Sentra II (a.k.a. B13 platform) ay available in base, 1.5 GSX, and 1.6 models (nissanbayan peeps, please confirm). Ang top of the line models ay yung yellow ang front clearance lamp, walang fender signal at nasa extreme edges ng taillamp ang signal lamp.
    Sentra III (a.k.a. B14 platform) available in JX, EX, Spirit, LEC, SS as well as other limited models like the Super Touring and GTS. May 1.4 and 1.6 (ga16) engines. I forgot the other engines in the range.
    corolla 1989-1992 aka ae92
    variants: xl, xe, gl
    xl - 2e engine , no ps(bare model)
    xe - 2e engine, ps
    gl - 4afe engine, ps , power windows
    2e-12 valve carb engine
    4afe - 16 valve efi engine
    corolla 1993 ++ aka ae100
    variants: xl,xe,gli
    **almost the same specs as the ae92 except for the different body shell****
    lancer models: (el,ex,gli,glxi)
    i think these models where available from the year 1993-1997 except for the ex model which as otep said was reintroduced along with the newer "pizza" lancer
    el - 1.3 4g13 engine, bare model
    ex- same specs as el
    gli - 1.5 4g15 engine , ps
    glxi - 1.6 4g92 engine, all power
    4g13 - 1.3 12 valve carb engine
    4g15 - 1.5 12 valve efi engine
    4g92 - 1.6 16 valve efi engine
    i think the b13 platform was the sentra 1, coz as far as i can remember the sentra2 is dubbed as the lec body and the sentra 3 is known as the "super touring" body. (not sure about that)
    sentra 1
    1.5 sgx(?)
    1.6 sgx
    sentra 2
    1.3 lec
    1.4 jx
    1.6 super saloon
    1.6 super saloon se
    sentra 3
    1.4 se saloon
    1.6 super saloon
    1.6 super saloon se
    1.6 gts
    1.6 exalta
    (the gts and the exalta was a facelifted version of the series 3 body)
    sentra 4
    1.3 gx
    1.5 ds
    1.6 grandeur
    (this is the latest model of the sentra that u can see in the showrooms)
    Regarding the Sentra
    Sentra series 1 (1988-1991)
    chassis code: B12
    engine displacement 1.6 1.5 1.4 and diesel
    nickname: boxtype sentra
    noteworthy: powersteering
    Sentra series 2 (1992 - 1995)
    chassis code: b13
    engine displacement: 1.6 1.4 1.3
    variants: Super Saloon, LEC, SE Saloon, Super Touring
    top-of-line engine type: 1.6 liter GA16DE (110hp)
    noteworthy: independent suspension, ABS (1993), all power options, fuel injection, variable engine ignition timing
    nickname: series 2, LEC-type, ECCS
    Sentra series 3 (1996-1999)
    chassis code: b14
    variant: super saloon, LEC, SE Saloon, GTS, Exalta
    top-of-line engine type: 1.6 liter GA16DNE (105hp) later GA16DE (110hp)
    noteworthy: rear beam suspension, power folding side mirrors, sunroof available on certain models.
    Sentra series 4 (2000-current)
    chassis code: b15
    engine displacement: 1.6 etc
    variant: grandeur, etc
    noteworthy: brand new efi engine, new chassis
    yung mga unang batches ng AE92 GL (the CBU ones) pawis lahat.
    ae92 = 4af not 4afe
    add'l info:
    regarding sentra:
    series 3:
    1.4 ex saloon pala yun lower variant
    1.6 super saloon yung middle variant (all power)
    1.6 super saloon se yung top of the line . + 4 wheel discs /abs
    1.3 fe - a bare model introduced in the year 2k -2k1
    series4:
    1.3 gx - bare model but still using the b15 body shell ;
    1.5 ds - middle variant
    1.6 gs superio \
    1.6 grandeur / not sure whos the top of the line variant
    between the two. i just saw both cars in c5 but with different model trim.
    btw noteworthy of the sentra 4/b15 is the new QG engine. which is equivalent to the award winning VQ engine used in the cefiro.
Different Car Specs
