Results 21 to 30 of 45
March 26th, 2008 10:08 AM #21
brake muna then clutch - high speed
clutch muna then brake - low speed
malakas busina, brake, clutch, sabay kabig - pag nataranta
March 26th, 2008 10:49 AM #22
depends on the speed and RPM. otherwise, most of the time brakes first for me.
March 26th, 2008 11:07 AM #23
Dapat preno ka muna,- hindi ka mamamatayan ng makina habang gumugulong ka pa. At the point na halos papahinto ka na,- step on the clutch pedal, change gear and then step on the gas pedal to accelerate.
Sa mga humps naman, marami rito sa BF Paranaque niyan,- you should not make a full stop sa mga humps dahil lahat ng sasakyan dito,- parang speed bumps lang ang mga humps at baka magulat sa sudden stop mo,- bubungguin ka sa likod.
So preno ka muna and then just before hitting the hump, release you foot on the brake pedal so that the front tyres will absorb the impact, else it will be the suspension. And then, once the front tyres are over the hump, step on the clutch pedal, change gear (for me, 2nd) and step on the gas, releasing the clutch, to get the rear tyres over the hump.
Another way is to step on the brake pedal and just before hitting the hump, step on the clutch pedal, change gear (for me, 2nd) and gently step on the gas, releasing the clutch, to get the front and rear tyres over the hump.
5707:tumbleweed:
March 26th, 2008 11:45 AM #24
kung high speed, heavy braking and low rpm and braking --> clutch then brake
kung high speed slow down lang --> brake until bumaba yung rpm to 1.5k then clutch.
March 26th, 2008 11:50 AM #25
Ako brake muna before clutch pero yun na nga around 1k sa odo apak na sa clutch the set to neutral and use the breaks until full stop. This is for my Landcruiser, I think different cars have different points so testing testing na lang....
March 26th, 2008 08:00 PM #26
brake muna, i rarely look at the odo pero somehow i feel when i need to step on the clutch para di mamatayan ng makina.
March 26th, 2008 08:31 PM #27
pag sobra bagal talaga clutch muna then brake, other than that brake then clutch na.
- Aug 2007
- 354
March 26th, 2008 09:03 PM #28brake muna then clutch then change gear, yun isang advantage ng A/T wala ka pagpipilian brake lang
- Jan 2008
- 337
March 26th, 2008 09:31 PM #29Sa high speed break muna, then kapag sa tantsa mo controlled na ang traction pwede na clutch then change gears. Delikado maging clutch driver especially during cornering and u decided to change gears, dapat sobra saglit lang naka disengaged makina sa tranny. The idea is to maintain traction through the help of the engine and avoid wheel spin. Sa low speed at city driving depende nasa mood.
