Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Aug 2005
    where can i acid etched my new car?
    Please send blackmagic a PM or just call 4150979
    Aug 2005
    Quote Originally Posted by theveed
    thanks theveed. i called already yesterday. sayang at di sila gumagawa (etching) on sat & sun. will bring my ride after all saint's day na siguro.
  4. #4
    mga sirs panu naman kung mag-papalis ng acid etch na un? nakabili kasi ng rear windshield dad ko na may naka-etch pang plate #....uyy, di carnap ung pinagbilhan nyan...
    Aug 2005
    Quote Originally Posted by alwayz_yummy
    nung nagtanong kasi ako sa big bert, di na daw matatanggal yung acid etch.
    you can't remove it. yun nga yung point ng etching eh.
    Sep 2004
    anti-etch? hehe lagyan mo nalang ng sticky sticker hehe :-D
    which is better? Laser etch o acid etch?
    Jan 2003
    same lang ang laser etched with acid etched both can't be erased or reversed. but the thing with laser etching is that since the laser is in a machine you will have to remove the part you have to etch so we can laser etch it for you.
    another process is sand blasting which blasts micro emery powder onto the surface, like acid etching, this process uses stencils. also canot be erased. different process has advantages on certain materials and applications. we only do laser and acid etchings...
  9. #9
    so, ang solution nalang is lagyan ko ng very sticky black tape para matakpan lang ung laser etched...
    hirap kasing body parts nitong maxima!
    thanx din...e kung papatungan ko ung etched na plate# ng solid na rectangle para mapatungan lang un....
    pag etch no way to revert it back, etching may be done on almost all glass surface, ceramic n porcelain, pede din sa ipin
acid etching
