Results 1 to 7 of 7
- Jan 2011
- 1
January 23rd, 2011 07:39 AM #1Share nyo nmn mga good and bad experience nyo oh sa sasakyan ntn.. salamat..!! ^_^
- Dec 2014
- 6
December 21st, 2014 10:04 PM #2
- Jan 2015
- 2
January 14th, 2015 12:13 AM #3Hi i need help meeun akong ford lunx 02 ghia nag over heat ako pina top overhaul ako kaso ngayun ning mabuo n ang engine ayaw naman ng mag start baka naman may makatulong sakin
- Sep 2015
- 6
September 27th, 2015 08:07 PM #4Hi.. Ask ko lang kung napagawa mo na ung lynx mo po? baka may kilala ka pong ford (or not) mechanic na ng hohome service, Automatic transmission po ung akin.
Thanks po. Cavite area din po ako.
- Sep 2015
- 1
September 28th, 2015 06:08 PM #5Mga sir can anyone post pictures of their aftermarket car stereo wires connected to their ford lynx ghia 2002 pls? Thanks
- Apr 2015
- 140
September 28th, 2015 11:30 PM #6Sir, check if all sensors are connected. Pag may isang sensor na nawala sa lynx ndi na yan aandar, or its timimg may be off.
- Nov 2016
- 1
November 8th, 2016 10:04 PM #7My car is ford lynx gsi A/T 2002 model.alam ko na napakaraming ford lynx user na may same problem as mine.namamatay yung engine after a few kilometers,and pag inistart mo sya..hindi kaagad sya magstart unless ipahinga mo sya ng 5 to 15 mins.depende sa init ng makina.pag napahinga mo na sya siguradong aandar.napansin ko na biglang nag da drop rpm.parang mawawalan ng kuryente at nag sha shut off. May mekaniko na ni refer sa akin at ayun gumastos ako ng 18k pero walang nangyari.eto po list lahat ng ginawa at pinalitan sa akin.
Fuel injector calibration 4pcs P2000
Fuel pump P2800
Adaptor socket ng fuel pump P 500
Ignition coil 2 pcs P 4500
High tension wire 2pcs P 2400
Fuse box P 1800
Labor P 4000
TOTAL: P18000
Hindi pa po kasama palinis ko ng IACV at surplus na camshaft sensor. Umabot ng 1 month na pabalik balik mekaniko sa akin.
Then may nakausap ako na taga ford.he honestly admitted na napakarami na nilang customer na nagpapagawa.pinapalitan nila ignition coil,at iba pang parts pero actually ang pinagmumulan pala nun ay ignition module or engine wiring harness.pag napalitan po daw yun ay 100 percent na wala na kayong magiging sakit ng ulo.sa mga meron pong ford lynx..bka makatulong po ito sa sira ng oto natin.as of now.plano ko na na ipagawa at palitan yung sinabi nung taga ford...update ko po kayo as soon na magawa yung car ko.thanks..sana may mag share din ng same problem na naranasan nila sa ford lynx nila..Godbless po.
Tesla Philippines
