The BR mags cost is 90K based on their breakdown. Worth it ba siya?
Sent from my HUAWEI MT7-TL10 using Tapatalk
Printable View
Pero ganda nga ng stance have you noted yung wheel/tire sizes?. From the pics it looks like a Rhino wheels and Safiro tires😀
Close but maybe not. BR 18 inch mags cost only P36k max. What tires are those? 265/65R18 all terrain nittos? 12.5K each x 4 = 50K. So total is only P86K. But if they use achilles a/t tires or kumho/nexen a/t tires which are as good as the nitto (less japorms lang) nasa 8.5K each lang. So check mo ulit anong model and size ng mags, and what brand, size and thread pattern ng tires then canvass ka sa olx to compare.
Well sir am kinda tipong motorheads. And I believe na those can lengthen/preserve my engine conditions😊 Oil catch can to avoid fouling of intake manifolds n valves, additional fuel filter for preservation of fuel piezo injection nozzles; better oil filter + Strong Magnet (to catch fine metal particles) for more engine protection; ETC electronic throttle controller for faster accelerator response to compensate for turbo lag;
WAI for extra power + cleaner piston and valves. Am not keen on blanking EGR..
hello mga sir and maam. ask ko lang ano ba dimension ng stock mags ng ambiente? planning kasi to buy new mags pero retain ko lang ung tire nila. tska need p ba ng spacer if ever ? and mag pa lift? thanks po
Just got my Everest Ambiente (A/T) last Saturday. Ang sarap i-drive, ang lambot ng manibela.
However, there are 2 issue that needs to resolved....
AIRCON
When I switch on the aircon, there is a lag of 2-3 seconds before it operates. Normal ba?
RADIO
Whenver I tune in it to 93.1 (kahit naka-save na sa preset), mag-play ng sandali then it will by itself switch to 98.7, 102.7 and 91.5. Then if I tune into to 102.7, lilipat naman sya sa 93.1, 98.7 at 91.5. Those 4 stations ang palaging nagpapalitan.
