Results 1 to 8 of 8
    Anyone in this forum encounteed this.
    I had my aircon system cleaned after 4 years of use. However, after the cleaning, the level of coldness decrease comparing it with the original level before. I returned it to casa and told me that per their evaluation, its ok and the level pf freon is ok as well.
    Anyone who experience this? And, what did you do to achieve your desired cooling level?
    Thanks.
    Posted via Tsikot Mobile Ap
    May 2010
    Try turning both the front and rear ac. The ac blows colder air when both are on. Around 2-3°C cooler
    Posted via Tsikot Mobile App
    Jun 2011
    Malamang high pressure yan po...
    Sent from my C2305 using Tsikot Forums mobile app
    Oct 2009
    ano po bang mga parts ung mga pinalitan..
    nagpalit po ba ng filter dryer.
    nagpalit ng expansion valve.
    nag flushing po ba sa mga hoss at tubo.
    nag leak test po ba sila.after na linisin ung evaporator.minsan po kasi after na nilinis ung evaporator hindi sinasadyang mabutas.
    kaya after na linisin un eh ini lileak test muna bago ibalik.
    filter dryer ubligado kasi filter nga siya
    That's what I'm saying if there's no problem with your A/C hinde kailangan IPA cleaning. Lalo masisira.
    #retzing
    Jun 2012
    Sobrang init lang talaga ng panahon ngayon TS. Baka bago mo pinalinis, hindi pa mainit ang panahon. And I agree with <shadow>. Pag walang problema, huwag papalinis ang aircon.
    Naalala ko tuloy si wifey. Mabaho daw ang ibinubuga ng kanyang Altis kaya dinala sa Toyota casa. Ang suspect, may naipit na daga kaya kelangan daw linisin at the cost of Php12K! Sabi ni wifey, singhutin nya na lang. After a week nawala yung mabaho.
    Feb 2009
    Quote Originally Posted by confused shoes View Post
    nasinghot na ni mrs ?
    Dec 2023
    I'm having the same issue. My Ford Everest 2010 had a radiator issue, I replaced the radiator and then removed the thermostat. Then I had issues with my AC. I installed a new AC compressor, TX Valve, Ac Condenser and front Evaporator core. But gets cold when engine is cold or when driving. But at idle it blows hot air.
    Any idea what's wrong? Also my heater does not work too.
Aircon of my 2010 Ford Everest
