Results 1 to 8 of 8
May 24th, 2014 12:29 PM #1
Anyone in this forum encounteed this.
I had my aircon system cleaned after 4 years of use. However, after the cleaning, the level of coldness decrease comparing it with the original level before. I returned it to casa and told me that per their evaluation, its ok and the level pf freon is ok as well.
Anyone who experience this? And, what did you do to achieve your desired cooling level?
Thanks.
Posted via Tsikot Mobile Ap
May 24th, 2014 01:44 PM #2
Try turning both the front and rear ac. The ac blows colder air when both are on. Around 2-3°C cooler
Posted via Tsikot Mobile App
May 25th, 2014 02:20 AM #3
Malamang high pressure yan po...
Sent from my C2305 using Tsikot Forums mobile app
- Oct 2009
- 2,271
May 25th, 2014 02:58 PM #4ano po bang mga parts ung mga pinalitan..
nagpalit po ba ng filter dryer.
nagpalit ng expansion valve.
nag flushing po ba sa mga hoss at tubo.
nag leak test po ba sila.after na linisin ung evaporator.minsan po kasi after na nilinis ung evaporator hindi sinasadyang mabutas.
kaya after na linisin un eh ini lileak test muna bago ibalik.
filter dryer ubligado kasi filter nga siya
May 25th, 2014 05:10 PM #5
That's what I'm saying if there's no problem with your A/C hinde kailangan IPA cleaning. Lalo masisira.
#retzing
May 25th, 2014 05:17 PM #6
Sobrang init lang talaga ng panahon ngayon TS. Baka bago mo pinalinis, hindi pa mainit ang panahon. And I agree with <shadow>. Pag walang problema, huwag papalinis ang aircon.
Naalala ko tuloy si wifey. Mabaho daw ang ibinubuga ng kanyang Altis kaya dinala sa Toyota casa. Ang suspect, may naipit na daga kaya kelangan daw linisin at the cost of Php12K! Sabi ni wifey, singhutin nya na lang.After a week nawala yung mabaho.
- Feb 2009
- 54
- Dec 2023
- 1
December 27th, 2023 01:13 PM #8I'm having the same issue. My Ford Everest 2010 had a radiator issue, I replaced the radiator and then removed the thermostat. Then I had issues with my AC. I installed a new AC compressor, TX Valve, Ac Condenser and front Evaporator core. But gets cold when engine is cold or when driving. But at idle it blows hot air.
Any idea what's wrong? Also my heater does not work too.
Tesla Philippines
