Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 80
    Jul 2014
    Feel free to ask any concerns about your ford cars. I'll help you. Or better yet, i can fix it for you.
    Mar 2005
    Nice. Is it advisable to buy a second hand focus tdci manual or power shift?
    The latter has so many problems and expensive to repair?
    Also is the manual focus tdci clutch lining different than standard linings? I read somewhere its about 80k to replace the clutch release bearing and pressure plate?
    Thanks
    Posted via Tsikot Mobile App
    Jul 2014
    Sir for me, the manual type is more advisable. Marami po kasi problems ang automatic. And true po na expensive po ang parts ng manual focus tdci pero hindi po siya sirain. If theres proper maintenance, matagal po bago masira or mag wear out. And mas marap dalin ang manual transmission. Its up to 6th gear. Maririnig niyo pa ang turbo everytime na switch gear. Honestly, the diesel type of focus encountered so many problems that ford cant perfect. Kaya nga po wala ng nilabas ulit na diesel. Pero for me, if i have the money, bibili rin ako ng focus tdci, matulin po. Hehe!
    Apr 2008
    Sir ano ba ang ginagamit na atf sa ford escape 2009 model?
    Jul 2014
    Quote Originally Posted by TAZ13 View Post
    Sir mercon V po.
    Mar 2005
    Salamat luigi, as follow up. Madami pa problema ang focus tdci aside from transmission?
    Ano po pa?
    Also parang gusto ko ng expedition na 02 tapos convert sa diesel. May gumagawa sa muntinlupa using surplus engine u like hehe. Any comments on this? Sirain din ba expedition?
    Jul 2014
    Quote Originally Posted by jasonub View Post
    Ano po pa?
    Basta with proper maintenance, ok po ang exped.
    Jul 2003
    Sir Luigi, my focus 2009 AT got Transmission fail and will not start, starter won't run. Shifter Lock when depressed, panel displays 'R' even when not moving the shift lever. what could be the problem. Just drove it for about 50km and when I placed it in reverse, cannot put it back to drive.
    Aug 2014
    Hi! I own a Ford Escape that was converted to LPG. The engine would start but would shutdown after a few seconds. Unfortunately, I can't locate the company where I had it converted anymore and their shop in E. Rodriguez has closed. Can you help me find out where I can have my vehicle fixed? Thank you.
    May 2011
    ^ you may try contact xoom auto gaz. they might be able to help you
    https://www.facebook.com/xoomautogaz...hoto&sk=photos
Ford mechanic
