you DIY the cleaning of the throttle body or in a shop? how about the intake manifold, have you tried cleaning it too?
DIY... If you wanna clean your entire intake system try Revive...
Revive turbo cleaner and power restorer for diesel and gas
Price : 5,5php
REPAIR WITH REVIVE
Revive is used to clean engine systems that already have problems caused by soot & oily build up.
By performing three Revive cleaning doses on the vehicle, carbonised layers are removed gradually, making the engine cleaning process very safe.
RESTORES ECONOMY, POWER & EMISSIONS
Cleaning the turbo and other engine internals helps restore fuel economy, regains lost power and reduce exhaust emissions.
VARIABLE VANE TURBOS
Variable nozzle / vane technology can be a major cause of turbo problems due to sticking turbo vanes, cleaning with Revive helps remove soot & oil from the mechanism to restore normal movement.
