Results 1 to 3 of 3
- Jul 2004
- 2
August 18th, 2004 11:15 PM #1gud day
pls help naman sa idling ng oto ko, pag wala a/c medyo mataas 1000rpm , pag switch ng a/c masyado bumababa idling , rpm fluctuating from 400 to 600 , masyado mababa causing the engine to vibrate kc masyado mababa idling. di ko tuloy maalis paa ko sa accelerator pag naka a/c , hirap pag nasa traffic kasi parang palagi mamamatay engine sa baba ng rpm.
d ba dapat pag switch ng a/c dapat tumaas pa rpm , bakit cya bumababa pa.
meron ba ako dapat i-adjust o palitan na part?
pls. help.
salamat
August 18th, 2004 11:50 PM #2
sa palagay ko lang.. may sira kotse mo.. dapat kasi pag on mo aircon.. automatic medyo tataas rpm mo dahil mas magbibigay ng gas sa engine mo.. but dahil yung switch mo dun... ndi lumalakas pasok ng gas.. and naaagawan ng compressor mo yung lakas ng makina.. kaya bumababa idling...
yan po sa palagay ko lang.. but ndi po ako bihasa sa makina.. you might want to wait for what other think.. hehe good luck po
August 19th, 2004 08:43 AM #3
It might be a defective idle-up solenoid that is the cause of your problem. This supposed to adjust your idle RPM when you are using the aircon.
Tesla Philippines
