Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
    Quote Originally Posted by brushless View Post
    There's already the front grille for air flow to keep the engine bay cool. Why the need to do that? Design flaw? It's not a sealed system.
    low end, wala talaga sealed, meron vent.
    partially open thermostats perhaps? hence their need to open their hoods?
    FOCUS
    Dec 2017
    #22
    They can always do a mod and install a hood vent. That would also look cool as well. LOL!
    Dec 2017
    #23
    there is only one temp gauge. yesterday after we got back from punta fuego the engine area was really warm. "radiant heat" this is the warmth im referring to.
    the radiant heat was very bad. when we were idling at fronte grabe the engine area you can feel it talaga. when the mech removed the thermostat housing the coolant was steaming. sabi nga ng mech, its looks new! medyo engot lng sya, all thermostats look new in a sealed system(santa fe). then this evening the engine was warm but not as warm. drove from marikina-bgc-marikina for a client meet.
    the santa fe has two cooling fans. one for the radiator and one for the condenser. these two were enough to keep the temperature in check but the radiant heat was bad as well as the fc and the AC performance.
    FOCUS
    I see that you were referring to the radiant heat which I became confused. How about the coolant lost, can you explain how that happened?
    I've read this thing but coolant lost wasn't mentioned:
    Do I need to Change My Car Thermostat? | BlueDevil Products
    6km/l before thermostat change
    7.3+ after (no express way)
    both 60+ liters (full tank method)
    happy happy joy joy [emoji16]
    FOCUS
    #25
    ^ Is this for your Elantra? What were the symptoms aside from the radiant heat and bad FC? Did the temp gauge rise above its normal level?
    #26
    Bro stock, do use an obd scanner/reader?
    It would've been interesting to compare the working temp of your cooling system pre & post thermostat change
    Quote Originally Posted by Woof View Post
    results are for the diesel santa fe... traffic sucks! nag megamall kami twice! [emoji28]
    elantra does 12+ after and 10+ before..
    FOCUS
    i didnt ..
    santa fe has two fans. one for the radiator and one for the condenser. while idling here in c5 traffic under the scorching sun. malamig padin [emoji16]
    this c5-ortigas overpass is about to collapse [emoji52]
    FOCUS
    #29
    Whaaaaat? That is seriously good FC for an Elantra! Is this the 1.6 Gamma or 1.8 nu engine? M/T or A/T? Average speed for that mileage?
    Baka naman M/T pure highway driving yan running at 80 km/h? He he....
    Baka naman pure highway yan running at 80 pm/h? He he....
    its my car outside philippines. 2.0 MPI engine 6at.
    its got 260,000km too [emoji6]
    FOCUS
Thermostat thread
