Results 11 to 20 of 28
January 21st, 2015 06:41 PM #12
i disagree with this, sa owners manual natin ang nakaindicate lang dun is yung regular plugs lang ng NGK and denso,
my car too is a honda jazz, and currently it uses regular plugs. wala naman pugak.
been reading fitfreak.com for a long time and ang usual suspect sa kanila kapag ganyan is yung coil packs.
have it checked.
- Oct 2013
- 1,181
January 21st, 2015 07:47 PM #13Nyaahh... Kung hindi naman stock sa car ang iridium, wala naman yan dapat effect kung palitan mo ng ordinary.
- Apr 2009
- 429
January 21st, 2015 11:37 PM #14most new cars today are equipped with iridium plugs for longevity. But you can always buy them outside as long as you know the irdium-equivalent of your stock plugs. I still prefer Denso and NGK iridiums. You can always access their website if you want to know their models for your engine. Since they are long lasting, What i do is rotate them every 5-10k km mileage to prevent their treads seizing up in the cylinder head.....
- Aug 2012
- 2,767
January 22nd, 2015 08:49 AM #15
January 22nd, 2015 09:24 AM #16
pa double check mo lang yung ignition coil kung saan nag susupply ng current papunta sa spark plug. baka ito ang cause ng pag pukag. sa mga lumang car ang isa sa mga cause ng pagpukag ay current galing sa ignition coil, spark plug or contact point pero sa modern car ay wala na ang contact point kundi electronic na to. Hope it helps.
January 22nd, 2015 09:31 AM #17
January 22nd, 2015 10:08 AM #18
they check it also yung ICM ( ignition coil ), reset nang computer then noong pinalitan nila nang spark plug na iridium nawala ang pugak. So far wala na ako nararamdaman ngayon dahil pinahiram muna nila ako nang iridium na spark plug next for observation. Pero next week need ko na ibalik sa kanila.
Out of specs daw yung ordinary na spark plug na kinabit. Ok sa simula kasi bago ( pinalitan sya last sept 2014 pa ) pero pagtagal daw magkakaproblema kasi out of specs sya.
Kaso eto nakakatawa... Yung spark plug price ni greenhills ay Php 1,280 ang isa at yung sa cainta ay Php 612 ang isa ( lumang model nang iridium ang sa cainta )
January 22nd, 2015 05:41 PM #19
the only difference in specs would probably would be the heat range of plugs siguro... bawat model ng engine kasi ng vehicle meh specific heat range...
if the first 3 grooves ng thread is blacked, its ok, anything less than or more that (less than 2 grooves/ mroe than 3 grooves blacked) eh detrimental sa life and performance ng plugs...
ito probably and sinasabi na out of specs that eventually will lead to failure...
