Results 1 to 6 of 6
July 1st, 2010 05:57 PM #1
Mga sir ask ko lang po, sa mga nakagamit na ng both oil, alin ang mas ok? Planning to change oil po kasi on my 4JG2 engine, eversince kasi I'm using shell Helix Diesel ung nasa yellow container with 15w40 rating, so far ok naman ang performance change oil every 5k, may nag recomend lang po na friend na try using Mobil Delvac MX same 15w40, much better daw po than Shell, hingi lang po ako ng second opinion sa mga nakapag try na ng ganitong oil, anu po ang ma rerecomend nyo between the two since konti lng naman po ang price difference nila.
thanks
- Jun 2009
- 325
July 2nd, 2010 10:28 AM #2Better try Mobil Delvac 15W/40 and compare its performance with Shell Helix Diesel. Use a branded oil filter (Vics, Fram) during next oil change. Much better, have your engine undergo compression testing to check its condition.
- May 2010
- 15
July 2nd, 2010 07:03 PM #3pre try mo toh. if you want better performance ng oil or pag nag change oil ka na,..Try mo Lambda oil treatment bago ka mag change oil. a bit mahal pero sure ka pre maganda ang performance ng oil tsaka ng engine. kahit na anu oil gamitin mo gaganda engine mo. kung gsto mo other information about this one try to reached sa digic_tse*yahoo.com or tawag ka sa 632 8245859 tanong ka lng kung anu ung lambda na sinasabi ko. mabibigla ka sa kaya nyang gawin. tested and proven. regarding naman pre if oil alone mas maganda and shell for me.
- Jun 2010
- 47
July 3rd, 2010 05:56 AM #4Good day Sir try mo yong castrol oil 15w40 yon ang gamit namin dto good for the engine kaya lang medyo may kamahal ng kunti 10t km or more bago ka mag change oil,
- May 2006
- 913
July 3rd, 2010 10:18 AM #5why dont you try Valvoline oils.. i think they have one of the highest ratings for mineral oils.. for diesel i think the rating is higher than Castrol GTX diesel..
July 3rd, 2010 08:14 PM #6
try nyo rin ang shell helix plus diesel 10w-40. semi-synthetic na ito. php258 kuha ko.
sa experience ko mas quiet, mas smooth, madulas ang pakiramdam ng makina(parang walang karirap hirap) at nag improve ang fuel consumption ko. maski nakaka 5000km ka na parang bago pa rin ang pakiramdam ko sa makina.
although CF rated lang siya. pero it works very well for me.
Tesla Philippines
