Results 1 to 10 of 66
May 5th, 2003 04:28 PM #1
Alam ko usually 90 grade ang ginagamit sa mga sasakyan. It can be used for differentials and trannys.
We have 2 diesel-fed engines here, and usually sa umaga pag bagong andar ang makina hirap ipasok sa 2nd gear. Do you think it is safe to put 140 grade para mas malapot at baka sakaling mas madali na ipasok ang kambyo?
Another question is from the 4WD aspect. Ganun din ang circumstance early morning drives may naririnig akong sound coming from the front solid diffs. Safe ba gamitin ang 140 grade na lapot sa may mga diff lockers?
- 10,620
May 5th, 2003 04:55 PM #290 gamit ko kasi..............sabi mo eh he..he
seriously, sabi mo nga.
palagay ko safe siya, not sure though, pwera na lang kung super sobrang lapot
May 5th, 2003 06:27 PM #3
90 talaga ang gamit as recommended sa Haynes manual. Someone told me before that putting in thicker gear oil would indeed make gearing in a bit tougher. But pag laspag na ang tranny mas oks daw thicker oil. Sabi lang sakin...
May 5th, 2003 06:45 PM #4
kimpOy::: Yun nga rin kasi pagkakaalam ko 90 grade common on all vehicles, but a friend pointed out that 140 grade gear oil could help with the noise I'm hearing over my front diffs. Naisip ko tuloy kung pwede rin kaya itong subukan sa trannys.
pajerokid::: How would you grade yung laspag stage ng tranny? After the kilometers it ran?
May 5th, 2003 06:58 PM #5
ungas:: pag maluwang na ata yung kambyo. :mrgreen: Sorry pre wala akong 1st hand experience. Sabi lang sakin nung uncle ko.
May 5th, 2003 07:03 PM #6
Well, there's only one thing to find out, and hope it will work. Replace the front diffs and tranny with 140 grade oil. While the transfer case and rear diffs will remain 90. (baka kasi di bagay sa diff lockers ang masyadong malapot)
May 5th, 2003 07:16 PM #7
sir Ungas sabi ng aking source eh SAE 90 for light vehicles and 140 for trucks and heavy equipment...2 months old pa lang kamo yung gear oil nyo di ba?
May 5th, 2003 07:25 PM #8
chieffy::: Yup yup, yung dati naka 90 grade din kaso maingay yung front diffs ko pag bagong andar, assuming napalitin na yung oil. Nagpalit ako 90 ulit ang ginamit pero andun pa rin yung sound. Kaya balak ko mag 140 baka sakaling mawala kaya lang hindi ko alam ang negative effect kung makakasira ng piyesa.
BTW, palitin na pala oil seal ko sa harap kaya iniisip ko rin kung tama rin na palitan gear oil. May makukunan po ba kayo ng parts dyan incase I decide to change it at the same time?
May 5th, 2003 07:41 PM #9
i recommend you use Castrol Hypoy LS gear oil sa rear diff mo, it is designed for limited slip diffs, don't know lang the viscosity. baka effect na yan nag water fording ang noise in your diffs, we usually repack bearings and change gear oils once a month if we fcross rivers because of the roads we pass by going to the quarry.
btw have you extended your diff breathers?
May 5th, 2003 07:49 PM #10
ARB::: My ride is not equipped with rear LSD. Yung noise sa front diffs ko simula pa nung nakuha namin yung ride meron na.
Diff breathers infront are normally extended up to the engine compartment for Patrol models. While the rear are placed in one of the cross members. Hindi ko na pinalitan ito, may extra line pa naman for the suspension strokes.
Tesla Philippines
