Results 2,981 to 2,990 of 3899
- Jul 2012
- 56
December 1st, 2012 09:49 AM #2982
Guys i still have one piece of bd28... Pm nyo ako if interested...
Nag iisa na lang... Sayang naman, matatagalan pa uli bago meh dumating..
December 10th, 2012 10:21 AM #2983
Anyone interested with BD28? I have three available. PM me.
Sorry OT
December 10th, 2012 11:00 AM #2984
Hehe...got 2 LF3564 bought from filterbarn US, PM me for those who want it...hindi kasya sa rig ko tumatama sa intercooler hose kasi...mas wider sya compared sa BD28
December 10th, 2012 04:36 PM #2986
- Jan 2007
- 409
December 10th, 2012 04:54 PM #2987dvldoc
Hi dvldoc. I need some help here. I would want to run a filter relocation modification BUT the housing for the filter is small. Current or correct filter being used is a bd7160 but gasket diameter for the filter relocation would be able to fit a B2 diameter. Here is the data on the two filters.
B2:
Contains: Anti-Drainback Valve
8 PSID Front End By-Pass Valve
Descriptions: Dual-Flow Lube Spin-on
BD7160:
Contains: 11-17 PSID By-Pass Valve
I can't remember if I can run a higher or lower psid filter.
Thanks in advance for your help!
December 10th, 2012 11:24 PM #2988
I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
- - - Updated - - -
- Jan 2007
- 409
December 11th, 2012 02:00 AM #2989Sorry incomplete info. Thread pitch will not matter and I know filters have different pitch. The relocator has replaceable pedestal (I can't remember what you call the thing you screw your filter on.) so I can use either pitch what I need is for the gasket to hit the lip. The b2 seals on the lip well but has a lowered psid. You think I can use the b2 to replace the original filter?
Sent from my GT-I9100 using Tapatalk 2
Tsikot Member Rank 1
- Jul 2009
- 4,090
December 11th, 2012 11:25 AM #2990
