Results 21 to 30 of 3899
March 31st, 2011 12:35 PM #24
March 31st, 2011 12:40 PM #25
Yes the 4M40 has a combo filter, ie it has a full flow and bypass in one filter, also very common in the states.
example of course yours is not this big nore will it have the same media in it but it will be similar. You have two elements, a full flow section then a bypass section in one filter. As stated at the start of the thread bypass filtration is a mainstay for diesel engines.
Bypass / combo filter.
The 4M40 takes a Fleetguard LF3564
Physical Dimensions
BPV Setting 100 kPa (14.5 PSI)
Largest OD 106 mm (4.173 in)
Overall Height 136 mm (5.354 in)
Thread Size M26 X 1.5-6H INT
Primary Applications
MITSUBISHI MD069782 All Applications
Product Comments
* Combo style filter
As far as fuel filters that's pretty easy, you want 10 micron or better filtration. 15 micron is most OEM standards. You can get higher efficiency ones that go all the way down to 2 microns which will double your fuel systems life. You can't really add a 2 micron filter to a old school diesel because the lift pump might have issues flowing. New common rail is no issue you can add one in line with the stock pump.
You want less than 10 microns for a really good filter, Donaldson, Baldwin, Fleetguard and WIX all have these down to 2 microns.
On a diesel your fuel filter is just as important as the oil, Go cheap and you'll have problems.
Fuel filters are close to the oil filters in design as far as the filter media goes.
March 31st, 2011 01:34 PM #27
Diesel Engines generally use one of two types of lube filtration systems:
A Full Flow system
A Bypass or Part Flow system
A Full Flow system works the way it sounds. The entire flow of the fluid (oil, fuel, etc.) passes through the filter on its way to the engine.
In lube systems, the full flow filter is by necessity an open filter.
The full flow filter cannot restrict oil flow used to control larger particles, the full flow filter cleans all of the oil going to the engine.
A bypass or part flow system has a different flow path than a full flow
In a bypass system, a small amount of flow, usually controlled by an orifice, is taken from the main flow stream that oil is passed through a filter and then returns to the sump.
Due to the lower flow of a bypass system, a bypass filter can remove smaller particles.
Basic filter parts.
Filter Bypass Valve allows unfiltered oil to flow around (bypass) the filter. Not to be confused with a bypass filter Every lube system has a bypass valve.
May be part of the filter or part of the engine Antidrainback Valve Used for inverted applications maintains a head of oil to prevent dry starts. Used in conjunction with a standpipe.
Filter break down.
- Jan 2011
- 123
April 2nd, 2011 04:54 PM #28Useless ang paggamit ng modified filter na yan dahil hindi marami ang amount ng motor oil na nasa loob ng makina ng mga light duty diesel engines ng mga sasakyan natin.Hindi pwedeng patagalin ng mahabang panahon ang change oil di gaya sa makina ng mga malalaking trucks/buses.Ang ratio ng dami ng langis sa displacement ng makina will decide the size of an oil filter & change oil interval depending on what type of oil we use.
April 2nd, 2011 11:16 PM #29
Makes sure they are real Baldwin filters plenty of fakes in that part of the world.
Biggest thing to look for is.
Country of Origin - Baldwin manufactured filters are marked with the country of origin. Baldwin has manufacturing plants in the United States, the United Kingdom, Mexico, South Africa, Morroco and China. If it does not have this it's a fake just makes sure you getting what you paid for.
Other stuff.
Color
The color of a Baldwin spin-on filter may not be correct on a counterfeit filter. It may be close, but just not right.
Graphics
Graphics on the filters, including the logo, may be missing or incorrect. In the photo to the left, the counterfeit filter has 2 I's in Baldwin.
Components
A counterfeit filter may look right upon first glance, but upon closer examination, you may find major differences. Some places to look include:
Dimensions - The dimensions of the filter may not be the same as a genuine Baldwin filter.
Baseplate - The baseplate may look different or be made from a different material than that used by Baldwin.
Media Packs - Counterfeit media packs often have an obviously lower pleat count than Baldwin. In addition, the pleats may be deformed.
Gaskets - Both internal and external gaskets may look different or be made from a different material than that used by Baldwin
Real Baldwin box.
