Results 41 to 48 of 48
- Jul 2010
- 570
October 13th, 2013 03:10 PM #41Sa Lancer ay nasa likod ng radiator ang fan at pahigop ang hangin galing sa harap ng radiator. Ibig sabihin nalalamigan yun tubing ng radiator at malamig din hangin pasok hood. Nasa loob ng hood yun engine.
Di ko sure sa Vios kung yun fan ng radiator ay nasa harap ng radiator. Pero sure ako papasok ang malamig na hangin galing sa labas at dadaan sa radiator papasok hangin sa hood.
October 13th, 2013 03:20 PM #42
- 53,883
October 13th, 2013 03:34 PM #43now why would anyone want to turn his aux fan on and off manually, when a temp-dependent switch can do it automatically and more effectively?
malimutan mong i-on yan nang isang beses at warp ang head gasket... and when you have a guest driver, kasalanan pa siguro niya kapag..
re-wiring the aux fan back to auto mode is not difficult..
- Nov 2009
- 3,503
October 13th, 2013 03:46 PM #44^ LOL. ginawang human thermostat. Bakit nga ba hindi nalang ayusin ang thermal switch.
Halos lahat ng ng rad fan nasa likod ng radiator, yung nasa harapan or tabi sa aircon condenser.
Kaya minsan kapag busted ang rad fan hindi mo kaagad mapapansin kung nakabukas ang aircon kasi some of the air of condenser fan damay ang rad.
- 53,883
October 13th, 2013 03:46 PM #451. many modern direct-driven fans have a viscous coupling, sabi nga ni 12 volts. personally, i find this viscous mechanism more of a headache than an advantage...
2. most engines have a thermostat inside them, whether their fans are direct-driven or electric aux fans. the thermostat interferes with radiator-engine block coolant exchange, so that the block gets to optimal temp faster..
- Nov 2009
- 3,503
- 53,883
October 13th, 2013 04:09 PM #47sapat na ba ung hangin galing ng radiator fan na bumubuga sa makina para maapektuhan ang warm up time ng isang makina?
Sent from my GT-N7100 using Tapatalk 4[/quote]
no.
remember that in starting a cold engine, yung bumubugang hangin sa makina ay malamig din..
also, the heat coefficient of air vis-a-vis engine block metal, is so very small.. but if you can manage to vastly increase the surface area of the engine block, then we're in business. look at the air-cooled VW or most motorcycle engines..
that's why the designers included a thermostat in the engine block.Last edited by dr. d; October 13th, 2013 at 04:13 PM.
