Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Apr 2014
    Previously using Mobil Super 1000 15w40 and after that, Honda Vtec Lev 10w30 which are all Mineral Oil ...
    Engine was ok and noise is normal ..
    Change to Mobil Super 2000 10w40 Semi-Synthetic Oil .. Now the engine is very audible .. You can the valve tappets ticking ...
    Is it a normal noise of semi synthetic engine ?? Will it damage my engine in the long run ?? Or is it only Mobil because some say Caltex Havoline Semi Synthetic offers a silent engine ...
    Should I go back to Mineral Oil ???
    Car is Corolla .. Engine is 1.6 4afe ...
    Trying higher octane fuel.
    not oil related imo. time for tappet adjustment..
    Apr 2014
    Sabi nila hindi daw na-adjust ang valve tappets ng 4afe .. sa 2e lang daw yun ..
    Jul 2006
    Go back to using mineral oil. Try "thicker" oil this time, 20w50.
    Apr 2014
    Hindi naman knocking noise ang naririnig ko sir ... same fuel as before pa rin ginagamit ko .. mas audible lang ang noise ng valve tappets ngayon na nag semi-synth oil ako, dati sa mineral oil hindi naman ganito ka ingay ang tappets .. lalo nag pag operating temp na, tahimik na tahimik na ... pero ngayon sa semi synthetic oil, kahit operating temp na, dinig na dinig mo pa rin ang valve tappets noise kahit naka sarado ang hood ..
    Apr 2014
    sa mineral oil na mobil 15w40 at honda vtec lev 10w30, prehas naman sila tahimik ang makina ko ..
    nagka ganito lang ka ingay ang tappets after nag semi synthetic oil ako 2 weeks ago ..
    Jul 2006
    Synthetic oil has good detergent capabilities. Most probably, it loosened the "mineral" build-up on your valve train, hence the noise.
    Feb 2014
    don't fix if it ain't broken LOL i mean why change to fully synthetic anyway?
    funny i just saw my 90's corolla driving past earlier tonight, probably by it's 3rd owner. it's probably as old as your car. i never used fully synthetic on it
    btw when was the last time you checked the valve clearances? paano ba adjustment ng 4afe? shim based?
    Apr 2014
    Quote Originally Posted by Vodka View Post
    It's no fully synthetic .. its just a semi synthetic oil ..
    That's the problem .. all the mechanics and shop I've asked said there's no adjustments on 4afe's .. unlike the 2e engines that can be adjusted according to specs via shim ...
Noisy Ticking .. Is it noisy tappets ?? After oil change ..
