Results 1 to 10 of 21
August 19th, 2017 02:37 PM #1
Available currently is the highest spec diesel engine oil API CK-4 which offers the best protection and performance. Anyone knows a particular brand of diesel engine oil which is sold here in the Philippines which meets this spec? Highest I found so far is API CJ-4 which is available in most fully synthetic diesel engine oils.
API | New API Certified CK-4 and FA-4 Diesel Engine Oils are Available Beginning December 1
Webinar: New API CK-4 & FA-4 Diesel Engine Oil Specifications - YouTube
Sent from my SM-G920F using Tsikot Forums mobile appLast edited by roydok; August 19th, 2017 at 02:41 PM.
August 19th, 2017 04:23 PM #2
I think for normal applications API CI/CJ is more than enough. Why do you want an API of CK?
Sent from my Android using Tsikot Forums mobile app
- Jul 2009
- 2,618
August 19th, 2017 04:38 PM #3Locally wala pa ako nakita but in the US I've come across shell rotella t6 with the CK.
I think tama si K.I.L.L. apart from the new rating it is much like API's rating for gasoline oil (sl, sm, sn) a lot if not majority of top shelf 100% synthetics for diesel surpass CJ rating yun nga lang naglabas ng baong rating kaya ayan. Changing to CK specs may not necessarily give you tangible advantages you might be seeking.
Also yun na metion ko na rotella t6 was previously rates CJ ata kaya ngayon bago na packaging uli. I assume to incorporate the "new" specs. If they changed the formulation I'm not privy to that.
August 19th, 2017 06:55 PM #4
For better protection if its available.
August 19th, 2017 07:08 PM #5
ano recommended oil nakalagay sa owners manual ng vehicle mo? api-cf?
August 19th, 2017 05:33 PM #6
Fords statement on Api-ck
https://www.flsheriffs.org/uploads/d..._Statement.pdf
- Apr 2012
- 3,469
August 19th, 2017 05:37 PM #7Bat ba walang Rotella dito? May nakita ako sa Blade pero mongrade o old stock pa
Sent from my LG-H818 using Tapatalk
August 19th, 2017 06:11 PM #8
royal dutch brand(shell umbrella) ang rotella. but its branding will collide with shell helix diesel and their rimula diesel oils.
August 19th, 2017 07:09 PM #9
Minimum API CD or better.
August 19th, 2017 07:10 PM #10
My question is not about whether API CK-4 is enough or more than enough for my vehicle rather if it is available in the Phils. Thank you.
