Results 1 to 9 of 9
    Aug 2006
    Hello mga car guru's,
    Question lang po..since i bought the car (95 ESI D15b engine Manual), i notice that everytime i use the car from cold start then pass the 60kph then slow down until bumaba siya sa 60kph, iilaw yung check engine..pero walang nagbabago sa takbo, idle as in wala..pero pag hinde konaman pinalampas sa 60kph from cold start hinde naman siya iilaw..
    example:
    from house (Cold start) ginamit ko siya tapos pass 60kph, iilaw yung check engine light niya..pag pinatay ko naman yung engine then turn it on again, wala na siya kahit lumampas na ako 60kph..as in wala na..
    untill mga 5 to 6 hours na rest yung engine then uulit nanaman yung cold start sympthoms niya..
    i tried having honda shaw casa checked it, sabi nila unknown error code daw and they want the car to stay with them for 1 week to observe...e since wala akong ibang sasakyan..sabi ko pag tyatyaga ko nalang..
    i tried going to evangelista to have it check and what they did is replaced the speedsensor (without removing the negative wire sa battery) then pag gamit ko siya for 1 week, ok na..kala ko ok na ok na..pero this time bumalik siya and same sympthoms niya also nadagdagan yung problem, yung odometer bayun sa baba ng true milege ng oto, hinde na siya gumagalaw (dati gumagalaw) then yung true milege reading niya medyo hinde tama yung count..(Pano ko nasabi) - everyday gamit ko yung car and 1 way to makati from sta.mesa is 12km, so kung balikan 24km or 25km time 4 days = 100km dapat..pero napansin ko 57km palang siya..
    hinde kona alam gagawin ko..
    baka may advise kayo jan na nakaka experience ng gamito..pa share naman po..
    Thank you for reading sa napakahaba kong problema sa oto..hehe
    more power TSIKOT!!!
    sa passenger kick panel may green connector , kailangan mo jump wire para ma retrieve yung codes
    connect the jump wire and turn the ign ON , CEL WILL FLASH THE CODES
    What was the unknown flash\trouble code?
    Nag pa engine wash ka ba?
    Aug 2006
    hello mga peeps..update kolang po..
    i tried jump the green connector socket and i get a fast 1 blink and after 4 secs another fast 1 blink light..paulit ulit lang siya after 4 secs. interval..
    base sa error code nakita ko ay error code 1 which is Primary 02 sensor ang sira..
    ano kaya pwede kong gawin? pwede paba palinis yung sensor or bili na ako ng sensor?
    i tried asking evangelista about it..1k bigay nila surplus siya..
    magkano kaya brandnew nito?
    Thanks for the replies and for reading my problems..
    thanks
    Aug 2006
    ano mangyayari kung hinde ko muna papalitan yun? may masisira bang iba?
    Quote Originally Posted by earthlyken View Post
    walang masisira na ibang parts
    pwede ka sa universal 02 sensor kung mahal ang orig
    don't get a surplus baka pundi na yun
    Aug 2006
    Quote Originally Posted by bambino View Post
    Hi sir bambino
    may store po kayo ma recommend kung saan makakabili ng Universal O2 sensor po? may idea kayo kung magkano po? at kung anong brand ang maganda?
    thanks po..atleast alam kona na anong sira..hay..sakit sa ulo..hehe
    Kay speedyfix yata nagkakabit siya
    Nov 2003
    we can install it but you'll need the o2 sensor muna.
Check engine lights on
