Bad news for me. My 94 Corolla GLi needs an overhaul. Read the previous threads. The tell tale signs are there. Some smoke when I remove the valve cover cap and the oil dip stick. Some wet oil deposit on the tailpipe. A little bit more noisier than usual.
So I got an estimate from a shop the sells the parts and has a machine shop and inhouse mechanic along Proj 6 QC. I asked for their best price for parts and machine shop services, for the benefit of fellow tsikoteers na din.
PARTS
Overhaul Kit - 1650 Federal
Master Bearing -750 Taiho brand
C Rod Bearing - 450 Taiho
Valves - 1900 Fuji
Piston Ring - 950 NPR
Thrust washer - 280
Motor Oil - 480
Oil filter - 190
Spark Plugs - 600
Timing belt - 1680 toyota
Paint thinner - 200
Rags - 60
Silicon x 2 - 190
If engine is really bad:
Liner - 1700
Piston - 1800
TOTAL: 12610
MACHINING 16 Valve 4aFE
Resleeve - 1800
Rebore - 2800
Polish - 800
Fitting - 900
Regrind - 1800
Oil Seal Build up x 2 - 1200
Valve Seat and retappet - 4500
Washing - 400
TOTAL: 14200
Whew! Magastos pala. Di ko pa pinapagawa.
Do you think the quote is fair enough? Which of the Machining services are essential and which are optional? How do I know if I need to have them done on the engine?
Gurus, pa-advise at paexplain naman! HELP!
