Results 1 to 10 of 19
April 30th, 2005 02:52 PM #1
"Nippon Micro Filter". I bought it this morning at a local shop. It's a taller than OEM. Is it any good?Last edited by Psylocke; April 30th, 2005 at 03:04 PM.
April 30th, 2005 02:56 PM #2
i think we had that on our petron station b4, selling side by side with VIC, GINZA etc ok naman
April 30th, 2005 03:04 PM #3
Good to hear that. It's taller than OEM or VIC so I figured that company probably didn't skimp on the quality or materials...
Tsikot Member Rank 3
- Dec 2003
- 546
April 30th, 2005 03:07 PM #4pag mas mataas nag oil filter di ba apektado ang Pumping ng oil? di ba yung pump is based upon air vacuum? pag masmalaki ang vacuum mas mahina ang pumping?
April 30th, 2005 03:57 PM #5
ok naman yan.. it does the job... problem is, its softer than VIC, kaya pag papalitan mo na, usually nagcrumple... kaya medyo hirap minsan tangalin...
- Dec 2013
- 527
November 29th, 2014 11:52 PM #6Actually this brand is far better than VIC, as VIC has inferior filtration capabilities, you can search in google about VIC filter reviews and you will see a lot of tests about its filtration compared to the other brands, also Nippon Micro is widely use in SG, USA, Australia and etc...
November 30th, 2014 01:00 AM #7
I used that before so far okay naman pero mas better pa rin sakin ang baldwin. much cheaper pa. try it in your next change oil. ;)
November 30th, 2014 04:41 AM #8
- Dec 2013
- 527
December 14th, 2016 09:06 AM #9Actually Nippon Micro is also O.E. filter Supplier to Toyota & Fuso in Japan domestic market, so they do not skimp on materials or quality.. The reason why Micro is more expensive than Baldwin is that they manufacture their filters in Japan while Baldwin for third world countries like Malaysia or Philippines comes from China just like what Bosch is doing which is why they outsourced their filters depending on the country's market affordability.
- Dec 2013
- 527
December 14th, 2016 09:25 AM #10Like FIAMM horns which they sell here in the Philippines, they sell the cheapest FIAMM Autotech Co.,ltd.(China FIAMM) made in China models here because most of the people can not afford the ones Made in Italy or Made in USA which is very very expensive.
